I have emailed Vans support today, but also wanted to get some feedback here on an issue I have hanging the rudder. When the rod end bearings are set for the called out dimensions on DWG 7 for the space between the rudder R-802-PP web spar and the center of the bearing, the rudder does not clear the top of the VS, it contacts at the most forward point of the rudder with the VS. Significant adjustment to the rod end bearings, top and bottom is required, so that these two are no longer in tolerance as called out in DWG 7.
I know part of the issue, if not all the root cause is the rudder top R-713 was installed a bit off, as the trailing skin was slightly above the rudder skin, required very minor filing.
While waiting advice from Vans, I sure would appreciate hearing from folks that might have seen this issue, and what you did to resolve. I did not build the rudder, came with purchase, but I sure am tempted to just order the rudder parts from Vans and build anew...
On a long shot, I have a really nice RV7 rudder, I built at an RV builders class in GA, if someone wants to trade a nice 8 rudder for a 7.
