Hi all
I know this might sound a bit weired and it should have been sorted out many month and $ before. But it is how it is. And I am curious to know if other builders went through the same.
I am quite far along with my -7 emp. kit. HS, VS, and rudder are done while I work on the elevators.
Time has now arrived to spend lots of money for QB wings and fuse. For some reason I haven't ordered it yet. I put it off and off until I finally found out why.
I am concerned that the -7 demands too many resources of me. Financial resources during build and during operation. Builder's complexity skills/time during construction/assembly. I am asking myself if the -12 would be a better fit to me and if I would get happier with a -12 in the long run. The -12 does not cover everything of my mission goals, but still about 70%. That the -12 does not look as hot a -7, well I think I would get used to that.
Are there any builders who went through the same doubts, concerns when you already have started to build your plane? Have to switched to another model and do you regret or in contrary, are you happy to have decided that way.
Any thoughts on that are greatly appreciated in order to make up my mind.
Thank you very much.
