Reflex Flaps in the RV-12?
Bill_H
There is a fair amount of discussion here about reflex (negative) flap settings, and their effect, mostly for the RV10. Not mentioned for the RV12. When my flap(eron)s are fully retracted, I can push the button and move the handle down a bit. It won't stay there unless held (no slot) but it makes for about a 3 to 4 degree change on the flaperon. If I do it in flight, I get a substantial pitch up- about 5 degrees.
I haven't done an extended cruise check, I am wondering if anyone else has (or the factory.) Might this work out to a knot or two or three if cruising in this position? (Oops, I mean the benefit of cutting power to stay at a 120 kt cruise...) :D
I intend to run a check the next time I go up. Others?
Bill H N412BR "Sweetie"
The airfoil used on the RV-10 was specifically designed with a reflex in the shape at the aft portion (the ailerons are always in this reflex position).
The RV-12 uses the common NACA23XXX series airfoil (used on many aircraft from the Cub to DC-3). I don't think reflexing the flapperons on that airfoil will cause any reduction in induced drag.
After completing my RV-12 and while flying off the 5 hours, I climbed to 10,000 feet to do one of the test procedures. Upon reaching altitude and leveling off, there was a loud bang and airplane porpoised. That was very unnerving. I thought that I must have made a mistake building the plane and it was falling apart. It took me a couple of days to realize that the flap handle must have been below the retracted position. Leveling off made it snap into the detent.
Joe Gores
I did not like that little extra free play in the flaperon lever between the floor and the first notch -- it seemed a strange and somewhat annoying design feature for the reason cited by Joe above. By filing a bit of a ramp in the bottom flaperon notch and/or adding a bit of a flaps UP "limit stop" (AFTER your cert inspection of course ;)), this is no longer an issue for me.
Joe Gores
I'd have needed to spend those couple of days replacing upholstery. Just sayin'.
Mine has popped a few times. I took some evil delight in seeing the expression on my hot-shot retired fighter pilot friend's face when he was on a flight with me and it happened. :D
I tried it at cruise at about 4000 feet. I think holding the handle to the floor at the same RPM and altitude cost me about 1 Knot.
Sea Level on a Standard Day
Bill,
The 120 Kt limit only applies at Sea Level, on a Standard Day, at Max Continuous power. Change any one of those three factors and your limiting number is Vne. Whether or not that is prudent is another matter.
Tom
