After installing the cushioned clamp standoff in section 32-02 it became very obvious that the four brake lines from the right rudder pedals run forward of the electrical wiring harness. This is important as you want to route the brake lines correctly before you connect the brake lines to the brake reservoir T. I ground down the tips of a "clecoe" clamp to hold the cushion clamp during installation.
