  #311
Old 04-15-2019, 09:45 AM
Jetguy's Avatar
Jetguy Jetguy is offline
Actually it has been stated by Vans that the nose wheel strut has more drag than you would think! Expect an increase in 3 to 4 knots with the fairing on.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 04-15-2019, 10:47 AM
NORM T NORM T is offline
Jim,perhaps pleased, not shocked, would have been what I should have said. Thanks for sharing your opinion. Perhaps "significant" depends on your point of view. My evaluation was run on pretty much standard days, not same day, about 60 degrees F, 30"hg, AP straight and level, 3000' msl, 2800 agl, pilot only, maybe half tank fuel. Steady state at 5000 RPM: 100kts/no fairings; 105 kts/ wheel fairings, 110 kts/whl and strut fairings. I saw 120 kts at 5300 RPM, scary at 5800! I saw climb rates of 1000 fpm. All values my scanned readings, approximate but indicative, satisfied my purposes. Test by others will be different, I don't care, I like mine, may not be repeatable, evaluation was for my benefit and curiosity. I am not the builder, it was flying before my purchase. I like it! I really like it a lot! (On another thought, why do people have wheel pants on J-3 Cubs?) Have Fun, Jim.
Norm
Old 04-15-2019, 03:01 PM
I can speak with a fair amount of authority about J-3's having owned one for 23 years and some 1100 flying hours. The only thing wheel pants do on a Cub is keep mud from flinging onto the bottom of the wing. Makes a real racket when clumps of mud start hitting fabric wing like a big bass drum...
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 490
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
Old 04-21-2019, 10:22 AM
Comparing airspeed and fuel burn vs. engine RPM before installing wheel fairings and then with, and then adding the nose wheel strut fairings, I was shocked by the significant improvement resulting from the latter. It caused me to speculate about the exhaust pipe which is also directly behind the propeller. Could a V-cross section fin behind the pipe could be beneficial in drag reduction, and maybe in reducing exhaust gas stain on the belly? Has anyone done anything in this area? I would like to hear about such work if it has no ill effects. At least it is fun to think about such things!
Norm T
Bought ELSA RV-12 flying, great little airplane!
Had Grumman Cheetah for 20 years prior
Do you have any pictures you could post up on the nose wheel strut fairing?
Old 04-21-2019, 10:51 AM
rongawer rongawer is offline
I believe he's referring to the one provided in the kit with the wheel pants. See https://www.vansaircraft.com/service...revisions/36a/
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"
- Several others that are now just great memories for me.
DHeal DHeal is online now
See: https://www.vansaircraft.com/service...revisions/36a/
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 825+ hours (as of Sep 2019)!
VAF donation through June 2020.
Old 04-21-2019, 02:28 PM
Thanks, guys! 5 kt's is 5 kts.
Old 04-21-2019, 04:33 PM
5 KPH is a lot almost 5% of cruise speed. I don't think I see that kind of improvement with all three pressure-recovery wheel fairings. RV-12 is not a fast machine that would benefit from a lot of aerodynamic cleanup.
Nose strut is a round tube which is bad for aerodynamic drag. But strut is short ~ 30 and mounted almost 45 deg to normal airflow.
EAA #499867
Old 04-21-2019, 05:49 PM
E. D. Eliot E. D. Eliot is offline
Default Main gear fairings?
I have read of only one person trying to manufacture and mount a set of main landing gear fairings - believe that they use RV-8 lg fairings. Anyone else tried this idea out. Results? I'd expect a few more knots gained. Might reduce drag enough to get 120K at lower engine speed???
Building finally
Old 04-21-2019, 07:21 PM
Norm
Bolded, for statistical purposes, as real world results, under standard ATM conditions.
