Old 04-13-2019, 03:47 PM
AeroDog AeroDog is offline
Default New tank is blowing soap bubbles
After inflating the balloon, I discovered bubbles in four places. All the threads I could find with the search function discussed repairing tanks which have had fuel in them, and the overwhelming consensus is that these leaks must be repaired from within. I'm certainly hoping I don't have to open this tank up to do the repairs. The build manual simply says to fix the leaks and re-check. Any advice will be appreciated.
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2019
Old 04-13-2019, 04:14 PM
wirejock's Avatar
wirejock wirejock is offline
Default Tank repair
Jerre
I've heard of builders pulling a vacuum on the tank then applying thinned proseal or other thin sealant.
The other option is cutting access holes in the baffle, sealing then installing covers. One of our Colorado RV builders did it recently.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-13-2019, 04:48 PM
funflying funflying is offline
Jerre,
Sorry to here about the leaks but a little more specific about where the leaks are on the tank. IE around a rivet, on a seam, or a screw?
Larry mentioned the vacuum method and I too have heard of it but never tried it myself or know anyone who did it. Iím also interested in what would used to thin the sealant or what other type of sealant might be used.
Without seeing where the leaks are occurring if it were a around a rivet I would consider removing it and resealing. On a seam I would try cleaning off exposed sealant and use a blade clean as best you can between the pieces and reseal. And around a screw, clean it off, back it out, reseal and put it back in.
None of itís simple but it is definitely better to address it before fuel is in the tank.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 04-13-2019, 05:06 PM
RV6_flyer's Avatar
Originally Posted by wirejock View Post
Jerre
Sealant is available that is thinner. Search for 890A2 instead of 890B2.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-13-2019, 05:39 PM
Originally Posted by RV8JD View Post
I like your 'Vette's license plate! Quite apropos.
It took me a while to figure out where you saw that, then realized it's on my UNC-Charlotte web site. You must be an engineer.
Old 04-13-2019, 05:44 PM
Originally Posted by funflying View Post
Jerre,
Two leaks are in the rear corners (one upper, one lower). A third is in the center of a rivet (one that's suppose to be "solid.") The fourth is at the fuel return fitting.
Old 04-13-2019, 06:28 PM
Default been there
Jerre
Been there, done that. Pulled a small vac, sucked in proseal and let cure. I did not thin the proseal and my tanks never had fuel in them. YMMV
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 04-13-2019, 06:35 PM
DHeal DHeal is online now
With the newly-built tank dry of fuel and on your workbench, you will never have a better time to correctly address your leaks. Remove the forward access panel* and fix the leaks from within. Like a roof leak, sometimes the visible external evidence doesn't truly reflect the actual location of the leak. So think like a leak!
*Removing the access panel isn't that onerous a task. Use a thin flexible putty knife to carefully separate the panel from the tank; then thoroughly clean off the old sealant before reattaching the panel with fresh sealant.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 825+ hours (as of Sep 2019)!
VAF donation through June 2020.
Old 04-13-2019, 07:22 PM
wirejock's Avatar
Default Disassembly
I saw men in Mexico remove windshields and similar parts using a guitar "E" string. The big windshield company uses a similar device. Some sort of high tensile string.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-13-2019, 07:37 PM
John-G John-G is offline
Jerre -
+1 for removing the access plate and doing the repair from inside the tank. You will feel better knowing it is not a patch from outside the tank.
You may want to consider the careful use of a heat gun on the access panel. The heat will help soften the proseal ... making it a little easier to get a blade, putty knife or tool of your choice between the access panel and tank body.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2020
