Old 04-11-2019, 04:21 PM
FLY GUY FLY GUY is offline
Default GDL 82
Has anyone installed a GDL 82 with a GTX 327 TXPDR?
Old 04-11-2019, 05:01 PM
DanH's Avatar
DanH DanH is online now
I have. Likely to be a common combination.
http://www.vansairforce.com/communit...d.php?t=167287
http://www.vansairforce.com/communit...d.php?t=168704
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-11-2019, 10:14 PM
ALagonia ALagonia is online now
I did and it was quite easy. I had Stein fabricate the harness for me.
Old 04-12-2019, 06:56 AM
bobg56 bobg56 is offline
Yes, just got done last week. Mounted it in avionics area forward of fuse panel, added the "Failure light" ...mounted antenna next to GPS Nav antenna, used RG 400, also when you load the Garmin installation tool on your lap top, press your Windows button on keypad and search GDL otherwise you'll just have the uninstall tool in your downloads, this threw me off and I had to call Garmin, otherwise not too bad, also I spliced into the Red power wire for the Transponder for power.
Old 04-14-2019, 09:30 PM
Bad1996 Bad1996 is offline
I did the gdl82/327 combo in my Just Superstol, itís works great. I love the anonymous mode for off airport shenanigans ! Easy to install and set up.
Old 04-15-2019, 07:36 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Originally Posted by Bad1996 View Post
I did the gdl82/327 combo in my Just Superstol, it’s works great. I love the anonymous mode for off airport shenanigans ! Easy to install and set up.
The FAA still sees and knows who you are. This just shields your N-number from the dirty masses. Any shenanigans done while your system is on, stay online somewhere, in an ultrasecure FAA server - forever.
Bryan
Houston
Old 04-15-2019, 07:43 AM
DanH's Avatar
Reference please?
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-15-2019, 07:59 AM
Low Pass's Avatar
Reference please?
Don't have time to dig for a reference based on my recollection. But if you already have it one way or the other, then please go right ahead.
Bryan
Houston
Old 04-15-2019, 08:06 AM
mdoyle mdoyle is offline
I added the GDL 82 to my RV 12. The harness is easy to make if you have the proper crimper, same for the RG 400 cables for the antenna and GPS. Software from Garmin makes the configuration simple. I received confirmation from the FAA that everything is working correctly and I am now waiting on the rebate to arrive.
Mike Doyle
RV-12
RV-9A, Under Construction
Xenia, OH 45385
Old 04-15-2019, 01:02 PM
Reference please?
Big Brother...
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 421
LSRM-A Certificate 2016
Special Thanks... EJ Trucks - Crew Chief A-4 Skyhawks
and MJ Stricker (my flight instructor) - 1st Lt./Captain B-17H WWII
