Old 04-10-2019, 01:56 PM
Cyclone Cyclone is offline
Default Registration RV12
I'm wrapping up the build project and have a question concerning the Aircraft Registration process. Do I need the packet of forms from Vans including the Bill of Sale and such or can I just download from the FAA, fill out and send to the FISDO?
Rv-12. Empennage done
Wings done
Fuselage done
Finish kit done
Avionics in
Painted
Firewall forward in progress
"I have enough money to last me for the rest of my life.
As long as I don't buy anything"
Old 04-10-2019, 08:23 PM
I checked my AW package. It has three documents with a Vans signature: Bill of Sale, Statement of Conformance and the Affidavit of ownership.
Old 04-10-2019, 08:25 PM
I guess that really didnít answer your question. I reserved an N number without any of the paperwork I described, and as I recall I needed the bill of sale to complete the reservation.
Old 04-10-2019, 09:16 PM
Mel's Avatar
Mel Mel is offline
There are absolutely no "forms" required to reserve an "N" number. A reserved number is assigned to a person, not any aircraft.
You don't have to have an aircraft, a kit, or anything else. Just $10.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 04-10-2019, 09:38 PM
rongawer rongawer is offline
If you are going to register as E-LSA, or want to use the kit as a basis for meeting 51% as E-AB, you will need the Bill of Sale from Vanís; but thatís the only form you need from them. The rest of the forms are right here:
https://www.faa.gov/aircraft/gen_av/.../amateur_regs/
Ron Gawer
- RV10, N1530G (reserved). Build in progress.
- RV12, N975G, "The Commuter"
- Several others that are now just great memories for me.
Old 04-11-2019, 07:26 AM
In order to register as E-LSA, Vans Aircraft needs to fill out and sign and give to you FAA
Form 8130-15 "Light-Sport Statement of Compliance". Vans will not provide that form
unless you buy every part from them and assemble the RV-12 exactly per the plans.
Joe Gores
RV-12 Flying
Old 04-11-2019, 07:37 AM
David-aviator David-aviator is offline
Originally Posted by Mich48041 View Post
In order to register as E-LSA, Vans Aircraft needs fill out and sign and give to you FAA
Which is reason I have decided to go EAB. (experimental amateur build like RV-7 and 8 I built) We are getting paper work lined up right now. Have number reserved, waiting on Bill of Sale from Vans.
There is no advantage for me to go E-LSA, you end up with a quasi certified airplane, like a Cessna, very difficult to make any changes.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
I'm in, dues paid 2019 This place is worth it!
Old 04-11-2019, 08:17 AM
This is not correct.
An E-LSA is still an experimental aircraft.
True, to qualify for E-LSA you have to build it exactly per the KAI and present it that way for certification.
After certification you can modify it to any degree you choose.
The only limiting factor is that any modification can't make the airplane perform outside of the limitations of a light sport aircraft.
Scott McDaniels
Hubbard, Oregon
Old 04-11-2019, 11:19 AM
Default Thanks for the help
I have an N number reserved and initiated the paperwork from Vanís.
Still have some work to finish up along with moving to the hangar, inspection and transition training. I enjoyed the build a lot more than the paper work
Wings done
Fuselage done
Finish kit done
Avionics in
Painted
