Old 03-14-2019, 01:48 PM
AeroDog AeroDog is offline
Default Two-piece rear floor
When Van's introduced the two-piece rear bulkhead an option was offered for a two-piece floor panel. I'm trying to decide if I need this. What issue was this addressing? Thanks.
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2019
Old 03-14-2019, 04:13 PM
DHeal DHeal is offline
Absolutely! The two-piece rear bulkhead and rear floor panel greatly facilitate your inspection of the tail cone area, its contents, and the flaperon actuator components.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 800+ hours (as of Aug 2019)!
VAF donation through June 2020.
Old 03-14-2019, 07:27 PM
Thanks! I have the two-piece rear bulkhead and am about to install the tank, so now's the time to go for the two-piece floor.
Old 03-17-2019, 06:38 PM
After pondering this, I'm still not sure what the two-piece floor is doing for me. Sorry for being a bit slow here.
Jerre
Old 03-17-2019, 07:29 PM
The two-piece floor mod allows you to better inspect and lubricate the flaperon actuator mechanism and its associated rod end bearings, fixed bearings, actuation tubes, etc. In addition, you may have to comply with SB 14-12-06 / F-1206F Bearing Bracket Cracks (https://www.vansaircraft.com/service...s/sb-14-12-06/). Your aircraft may already be in compliance with this SB -- check to make sure.
Old 03-17-2019, 07:32 PM
MMiller MMiller is offline
The two piece aft baggage floor is intended for the Garmin G3X version. The ADAHRS bolts to a doubler on the left side cover. If it wasn’t two piece, you would have to remove the fuel tank to access the ADAHRS.
Old 03-17-2019, 09:57 PM
Even if you don't have a G3X system with an ADAHRS mounted under the cover plate you still need access to the area for inspection and maint. of the flapperon torque tubes and associated structure. If you don't have the two piece cover, you have to remove the fuel thank to access that area as David already mentioned.
Scott McDaniels
Hubbard, Oregon
