Old 01-08-2019, 04:30 AM
awmuhs's Avatar
awmuhs awmuhs is offline
Default RV12 and RV12 iS tailcone difference
Our teen building group, Southern Arizona Teen Aviation, is building 2 RV12’s
We received our first tailcone just before the iS version was released. Our second one was ordered after. We opted to order the iS fuselage and engine for the first airplane.
The second tailcone has an inspection opening and cover on the bottom that allows access to the filters, pumps and fuel drain mounted on the aft side of baggage bulkhead. The first tailcone does not have the opening.
We fabricated an opening for the first tailcone prior to mating the fuselage and tailcone.
For those who had similar timing to ours you may want to consider adding the inspection opening. I am not sure how you would get to the fuel drain otherwise.
Alan Muhs
Tucson, Arizona
Dues overpaid December 17, 2018
RV12Is Southern Arizona Teen Aviation: wings, empennage & tail cone completed. Fuselage complete, engine hung, installing wiring/avionics
RV10 flying since July 2014- 615 hrs as of June 2019
RV6A sold after 500 hours of flying
Old 01-08-2019, 06:24 AM
rolick22's Avatar
rolick22 rolick22 is offline
Default F-01282-L-1
Yes good point, for all those who don't know, it's all based on what version on the fuselage you have, if you have the legacy fuselage then your good without the inspection hole. If you have the newer iS fuselage then you will have to have the cut out, punched out by Vans, or if you still have the older tail cone then you must make the hole from scratch. I had the old version with no inspection hole. I ordered a new F-01282-L-1(bottom left skin) and will remove and replace the old F-1282-L (bottom left skin). I know I could cut a hole but then it would not be the same because of the flange that is stamped into the part and will make the panel flush due to the factory made flange. It's got to add at least 20 knots do to less drag.
______________________________________
David Rohrlick
PPSEL, A&P
RV-12iS
Empennage Finished
Wings finished to iS standard
iS Finishing Kit Finished
iS Fuselage Finished (mostly)
iS Engine Kit Finished
iS Avionics Kit in work
Serial#12-0864
N112DR
VAF donation made for 2019
Old 01-08-2019, 10:17 AM
greghughespdx greghughespdx is offline
Our engineering team made updates to the plans in Section 38iS/U (finish kit). The steps included there explain how to create the inspection hole are to be completed before mating the tail cone to the fuselage. Instructions and a template to address this are provided. You can of course purchase a new skin with the factory-punched hole, if you choose to do so. That's just a matter of preference.
On page 38iS/U-07:
NOTE: For early production tailcones without the access hole in the F-01282-L-1 Bottom Left Skin as shown in Figure 3, go to Page 38iS/U-23 for instructions to include the access hole.
And on page 38iS/U-23:
NOTE: The oval hole in the F-1282-L Bottom Left Skin provides
access to the fuel drain for RV-12iS installations and to the
gascolator for RV-12 ULS installations. The template for the hole
is found on Page 38iS/U-25, Figure 3. Use the call-outs in Figure
1 and on the template to complete the steps on this page.
Step 1: Position the template on the skin and secure with tape.
Centerpunch two of the four #19 holes.
Cut the template along the edge of the hatched area using a razor
blade to score the skin beneath. Remove the template.
Step 2: Drill the two holes per the call-outs. Use the F-01282A
(RV-12iS) or F-01282B (RV-12 ULS) Cover Plates as a guide to drill
the remaining two holes.
Cut out the oval shaped hole in the skin.
Use the nutplates shown on Page 38iS/U-07, Figure 3 as drill guides
to match-drill #40 the nutplate attach holes, then deburr.
Step 3: Return to Page 38iS/U-07, Step 3.
The plans and template are available on the Van's web site in the RV-12iS Service Info Revisions and Changes section, here's the direct link to the file:
https://www.vansaircraft.com/pdf/rev...2iS_38iS-U.pdf
Hope that helps!
greg
Van's Aircraft - Community, Media, Marketing
Van's web site | Instagram | Facebook
Opinions, information and comments are my own unless stated otherwise. They do not represent direction/opinions of my employer.
Building RV-8A since Sept 2014 (N88VX reserved)
Dual AFS 5600, Avidyne IFD 440, Whirlwind 74RV, Superior XPIO-360
VAF build thread - Flickr photo album - Project Facebook page
Hillsboro, OR (EAA 105)
Old 03-26-2019, 03:27 PM
rcarsey rcarsey is online now
Default making your own joggles
I'm almost at the point where I need to cut the access hole in the bottom of the tailcone (i have a pre-iS tailcone). See 38iS/U-23
After I cut the hole, is there a somewhat easy way to create a joggle?
I think I read about one guy who drilled out the entire skin and replaced it with a proper iS skin that had the joggle. I'm not willing to put in that amount of effort for something that few people will actually see.. but .. maybe using a small die set and giant C clamp over and over again, I can make it ?
Old 03-26-2019, 03:57 PM
llavalle's Avatar
llavalle llavalle is offline
I don't know about you but the hole seems awfully small for maintenance on th pumps and related hardware - I'm almost tempted to enlarge it....
Philippe Marseille
RV-9A Kit Emp done, wings @50% - SOLD
RV-12iS@Empennage
Construction Web Cam
Old 03-26-2019, 04:36 PM
If you're building E-LSA you need to follow plans 100% without alterations prior to AW inspection.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 490
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
Old 03-26-2019, 05:18 PM
JFCRV12 JFCRV12 is offline
Related question: I noticed this RV-12 project for sale that has completed Wings and Empennage. Would I be able to purchase this kit and then the RV-12is Fuselage, Engine, Avionics, etc. and have an ELSA RV-12is? Or is that project too far down the RV-12 path to be considered?
https://www.barnstormers.com/classif...2+Project.html
Old 03-26-2019, 07:19 PM
Bob Y Bob Y is offline
We’ll have to go through the baggage compartment bulkhead opening to do any real maintenance on the fuel pump assembly.
Old 03-26-2019, 08:11 PM
In order to register as E-LSA, you must get form "8130-15 Light Sport Aircraft
Statement of Compliance" from Van's Aircraft. You need to talk with Van's to
see if they will issue that completed form to you.
Joe Gores
RV-12 Flying
Old 03-26-2019, 08:57 PM
The answer is yes.
The fuselage kit is what determines the eventual model designation. You will have to do the minor modification to the bottom tail cone skin mentioned in this thread but it is relatively simple and there are detailed instructions provided in the build manual.
Scott McDaniels
Hubbard, Oregon
