Old 03-30-2019, 09:05 AM
DaleB's Avatar
DaleB DaleB is offline
Originally Posted by John Acardo View Post
What does everyone think about the new style throttle spring?
Sample size of one: I like them so far. They were pretty quick and easy to install, and it's one less thing I need to worry about breaking.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 03-30-2019, 12:48 PM
todehnal todehnal is offline
Default Torsion Throttle Springs
I've had mine in for almost a year and about 90 hours now. They are fantastic. So glad to have them. They took an RV-12 trouble spot and totally eliminated it as far as I can tell. Thanks to the Van's engineering staff...........Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 03-31-2019, 11:36 PM
dbhill916 dbhill916 is offline
Thumbs up N=2
Doubling the "N" to 2, and maintaining a 100 % approval.
David B. Hill
N76012
RV-12 #0760
http://n76012.blogspot.com
Dues paid through 6-2019
Old 04-10-2019, 04:21 PM
peter52 peter52 is offline
For those that have installed the new SPRING 00002-1 springs what was the torque kn the bolt? Have perused the Rotax maintenance manuals and cannot find the torque.
TIA
Old 04-10-2019, 04:54 PM
Found it ..... 44 in. lbs.
Old 04-10-2019, 06:05 PM
AirHound AirHound is offline
The springs were designed to closely mimic the springs that have been supplied with the throttle control by McFarlane (hopefully minus the vibration induced fatigue failure).
The RV-12 fleet is pretty good size at this point and other than a higher failure rate of the springs than should be expected, they have generally given good performance.
The cables on the RV-12 throttle control are not much different than those used on motorcycles or bicycles, which have to be maintained to some degree.
If they are noted to be developing some friction that wasn't previously present, they can be lubricated with spray lube, and that usually restores them to the way the were previously.
Scott, Do you spray it into the cable sheath? How and at which end??
Doug
