Old 07-29-2015, 03:31 AM
Wolfgang M. Wolfgang M. is offline
Default RV-12 Tailcone J-Stiffeners
I started to assemble the tailcone. Page 10-06 Step 4.
Unfortunately the J-Stiffeners F-1283A & B do not fit at all. It is almost one hole diameter off.
Does anybody have an idea what could be wrong?
Wolfgang
Old 07-29-2015, 05:16 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default Picture
Could you post an image of that part please?
I remember that every time something hasn't fit or seemed ackward, it was always me who overlooked or misaligned a part.
I would be suprised if in your case the J-stiffeners of the skins don't fit in.
Chris, RV-12 S/N 120832, HB-YSC
flying
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2019
Old 07-29-2015, 05:36 AM
BigJohn BigJohn is offline
Go back and retrace all steps leading up to that step. It's conceivable a part could be wrong, but highly unlikely.
“Master Pilot” Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 07-29-2015, 07:09 AM
Default Image of J-Stiffener
Thank you for your reply.
I tried to send some Images, not sure how it works!
Wolfgang
Old 07-29-2015, 07:53 AM
Default Alignment
I am not in my shop right now so I can't answer 100%,
but to me it looks that the F-1283A stiffener should be placed outside of the J-channel of the skin.
In your picture it is located inside the J-channel.
flying
Old 07-30-2015, 02:55 AM
The F-1283A stiffener has to be placed inside of the J-channel of the Skin.
In the meantime I received some information from Vans. They are back from Oshkosh now.
This Problem is caused by a mis bent part and happened a few times recently.
It will be a quick and easy Job to fix.
Wolfgang, RV12
Empenage done
tail cone done
fuselage in progress
left wing done
installing the Rotax 912 iS
Old 07-30-2015, 06:36 AM
joedallas's Avatar
joedallas joedallas is offline
Default Page 10.06.04
Page 10.06.04
See more http://joesrv12.com/Builder%20Log/bl_10_06.htm
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 08-03-2015, 08:37 AM
waterboy2110 waterboy2110 is offline
I recall marking several sections that did not appear to line up and I was concerned. Once everything was cleco'd up it all lined up.
I do have some ripples over the stiffeners - common as I understand it. Vans said build it and fly it... so I will.
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P/IA Rotax iRMT 9 Series Maintenance
RV12 Flying.
Old 04-02-2019, 07:43 PM
scorkey scorkey is offline
Wolfgang, I came across the same problem with the holes not aligning when the stiffeners are placed in the J-channel of the bottom skin. (Empennage kit shipped Jan 2014)
What was the information from Van’s and the fix?
Old 04-04-2019, 12:28 PM
Jyuma Jyuma is offline
Hi Scorkey... you're asking a question in a 4 year old post.
I'm building the tail cone of an RV-12is right now and I have not had any alignment problems with stiffeners.
If you can be more specific... what part is not aligning with what part... I'll try to help you.
