Old 01-23-2015, 05:59 PM
Brendan03801 Brendan03801 is offline
Default VS-1211 and the com-3-5 bearing
Leave it to me to have trouble with my very first airplane part. On Page 6-02, there are instructions for assembling the lower hinge assembly and upper hinge assembly (VS-1211A between two VS-1210 hinge brackets, and VS-1211B between two VS-1210 hinge brackets).
I should be able to completely insert com-3-5 bearings into the large holes in VS-1211A and VS-1211B, but they don't... quite... fit. Is it okay to enlarge the holes a bit with a file so the com-3-5 bearings will fit? Thanks.
Old 01-23-2015, 07:52 PM
tomkk's Avatar
tomkk tomkk is online now
The bearings do fit into the recess. If I recall correctly, they're a fairly tight fit but not a press fit. They do need to be pushed in pretty exactly squarely, not cocked to one side. Did you prime the hinge brackets? If so, the thickness of the paint would be a problem.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 01-23-2015, 08:34 PM
Mich48041 Mich48041 is online now
I would not use a file, but maybe some fine sandpaper to remove any burrs. How about warming the brackets with hot water and putting the bearings in the freezer? If that does not work, order new parts.
Joe Gores
RV-12 Flying
Old 01-23-2015, 09:48 PM
Thanks guys. I have not primed yet - too cold out here and not good enough indoor ventilation. I will try the methods you mentioned.
Old 01-24-2015, 05:29 AM
BigJohn BigJohn is offline
Several of us early builders had problems with these, but if I Recall correctly Van's made a slight change to the parts to alleviate the situation. Search the old threads. How old is your Kit?
“Master Pilot” Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 01-24-2015, 08:04 AM
Big John, it's one of the newest - #893!
Old 01-24-2015, 10:55 AM
joedallas's Avatar
joedallas joedallas is offline
See
http://www.joesrv12.com/Builder%20Log/bl_06_02.htm
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 03-18-2019, 08:48 AM
llavalle's Avatar
llavalle llavalle is offline
Resurrecting this old thread. Was having the same issue with a Jan 2019 shipped Emp kit.
Asked Vans and they told me that since the VS-1211 are punched, the holes will need to be reamed, deburred, drilled, etc (paraphrasing here).
Mine doesn't fit at all in... the bearing doesn't want to get in. It's an interference fit.
Philippe Marseille
RV-9A Kit Emp done, wings @50% - SOLD
RV-12iS@Empennage
Construction Web Cam
