Old 04-01-2019, 10:51 PM
The way I remember the K-factor adjustment equation is to think of the K as the number of turbine revolutions per gallon. If your calculated fuel used is high you need to increase the number of revolutions per gallon and increase K.
Old 04-02-2019, 08:07 AM
DHeal DHeal is offline
Bill -- We are talking about an RV-12 here not an RV-7 type of aircraft. The RV-12 has a bypass/return form of fuel system with only one fuel flow sensor so the stock K Factor needs to be adjusted to reflect the bypassed fuel.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 825+ hours (as of Sep 2019)!
VAF donation through June 2020.
Old 04-02-2019, 12:48 PM
Tacco Tacco is offline
Thanks guys. Iím going to set the K-Factor at 110000 for my next flight (a couple days from now) and let you know.
Old 04-02-2019, 06:35 PM
BillL BillL is offline
Thanks - I did not know that - I have deleted the post as it is not relevant.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 05-04-2019, 12:22 PM
Just to follow up: my setting seemed to settle out about 110000.
