Old 03-21-2019, 12:10 PM
Tacco Tacco is offline
Innovative! ...and very cool. Pun intended!
Old 04-19-2019, 09:26 PM
Thought I might follow-up. The VR was indeed bad. Measured voltage from generator with engine running - looked fine. Measured output from VR with engine running - definitely not good. Unstable. Would go from zero to about 8 volts with no correlation to engine RPM. At no time did it ever get above 8v and then only momentarily.
So...acquired a new SH kit from Van's and installed per kit plans. Hardest part was repainting the cowling. Works fine.
By the way. I had also ordered a new Ducati VR before I just decided to go with the HS. So...I have a brand new Ducati regulator if anyone is interested.
Old 04-19-2019, 09:49 PM
DHeal DHeal is offline
Perhaps you might want to keep the Ducati VR on-board as a spare until the S-H regulator proves itself?
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 750+ hours (as of Apr 2019)!
VAF donation through June 2019.
Old 04-20-2019, 08:11 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default SH first Impression
I now have only about 3h with the newly installed SH VR.
So I can't say anything about long term reliability.
But I have noticed a positive charge also at low RPM when taxiing with consumers switched on. That was not the case with the Ducati. And now I also see a nice 14.2V voltage when flying. After the flight the VR is only handwarm at most. If the attached fan is really required I can't say for sure but it definitely does not hurt. I posted some images here in this thread http://www.vansairforce.com/communit...=64145&page=31
To me going with Silent Hektik was a good choice
Chris, RV-12 S/N 120832, HB-YSC
Phase I
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2019
