Old 11-09-2018, 05:01 AM
rocketbob's Avatar
rocketbob rocketbob is offline
Crank seal will sometimes whine as it starts to go bad. Noise will change with RPM. More like a faint squeal.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 11-09-2018, 05:58 AM
strahler13's Avatar
strahler13 strahler13 is offline
Does it change with changing cabin vent openings? Try yawing plane form side to side to change noise. Guessing canopy seal.
Mark Strahler
RV-6 (Purchased flying)
KFFC-Peachtree City, GA
Old 11-09-2018, 10:41 AM
bhester's Avatar
bhester bhester is offline
Default noise
When I picked up my plane after getting it painted, I had a whine noise that I did not have before getting it painted, it was pretty loud.
I accidently found it when I started feeling around for air leaks. I put my fingers in the area right between the canopy rail and the canopy skirt right beside me and the noise went away. The bottom pilot side canopy skirt was bent outward near the front just enough to cause the air to whistle or whine while in flight. I messaged the skin inward in that area and it has never whined again. It was caused by the canopy sitting on the table while it was off during the painting process. So check that area on both sides.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2018 VAF donator - alot better than any magazine subscription
Old 11-09-2018, 10:47 AM
Phil's Avatar
Phil Phil is offline
My backup battery for my G3X will make a faint whine when it is switched on. Itís not enough to be annoying, but itís enough to notice when the engine goes quiet. I kinda like it because it reminds me to shut it off after shutting down.
Another thought is to check the exhaust stack and see if itís sagging enough to hit the lower cowling.
Just a couple of more potential spot to look.
Old 11-09-2018, 11:06 AM
RV Jerry RV Jerry is offline
If you have a tipper canopy very good possibility the forwrward lip of canopy not sealing
Jerry Scott
Rocket II
Old 11-09-2018, 12:25 PM
Brantel's Avatar
Brantel Brantel is offline
Prime suspect. I have found that my seal is kinda miffed up causing it to push up on the lip of the skin a little.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-13-2018, 07:43 PM
Phaser24 Phaser24 is offline
I had the same type of noise (RV 7A with sliding canopy). Found one area where the weather seal had worn right over the pilot's head where the canopy meets the windscreen; fixed with new weather stripping.
Old 11-13-2018, 09:38 PM
Mark33's Avatar
Mark33 Mark33 is offline
Iíve heard that exact sound myself.
Old 11-14-2018, 06:57 AM
6 Gun 6 Gun is offline
Smile Whine
I chased a whine for months thought it had to be altenator changed it out twice and still there went to HF and bought a scope like Dr uses and by accident the tip crossed intake gasket at cylinder and found a pin hole making all the noise new gasket no noise.
Bob
Old 12-01-2018, 08:52 PM
Brantel's Avatar
So the mystery remains....
I have done some testing:
1. Put some tape over the front of the tipup canopy to cover the seam between it and the front top skin and flew the airplane to see if that is where the noise is coming from. Nope....its still there.
2. Did some RPM test to see if the noise volume or frequency changes with engine RPM. Nope....the engine RPM does not affect the noise.
3. Performed some airspeed test to see if the noise volume or frequency changes with airspeed. Yes.....the volume of the noise changes with airspeed. Lower volume at lower airspeeds and louder at higher all the way up to redline. The frequency seems very consistent.
