Old 11-07-2018, 07:44 PM
MElstien MElstien is offline
Default Moving a big Project - RV-10
Hello,
I am building an RV-10 in NJ and will be moving to Florida in a few weeks. I am keeping the home in NJ for a while. The home in Florida has a hanger. I wish to move my project to the new home soon. I am looking for feedback on the best way to move. I have builders insurance that will cover the cost of the parts and kits should something happen during the move, but obviously I hope nothing does happen. I have the following kits/parts in NJ
Epennange kit - completed
QB Wings on rolling stand 97% done Bottom wing skins and some wiring still left
Fusalage QB kit - as purchased
Lots of tools and boxes including compressor, floor band saw and drill press.
My thought is to rent a large U-Haul truck (not a trailer) for the airplane move. Pack the kits in custom built wood crates with just enough strategically placed spray foam packing (with plastic material between the plane and foam) to keep them in place. I can make the drive in 2 days.
Other options are to call a professional moving company, PODs, etc.
I think I would feel better doing it myself and knowing the kit is being handled by me, but paying someone is easier.
I would be interested in opinions and experience.
Regards,
Michael
Michael
Builders Blog http://elstien.us/wordpress/
Northern NJ
RV-10 Builder
Tail Kit delivered 6-2013
Started building April 2014
Empennage completed
QB Wing and Fuse Delivered December 2015
Finishing QB wings on September 2018
Dues Paid through 2018
Old 11-07-2018, 07:57 PM
I've moved a -10 kit. Here's what I would do. I'm sure others will chime in too.
Put the tools in the nose of the truck and lash them down very well.
Hang the wings along the sides of the truck using cargo straps and padding to keep the straps from damaging the wings. Use padding between the wings and side of the truck.
Alternately, I'd strap them down to the rolling rack, pad them well, and secure the rolling rack in the vehicle. It might fit side by side with the fuselage.
Place the fuselage in the truck and pack it full of ailerons, elevators, flaps, etc. You can fit a lot of flying surfaces in a fuselage. Obviously, you pad things well as you put them in there. Harbor Freight packing blankets are relatively cheap. Strap the fuselage down carefully. Do you still have the false spars and other hold down hardware from when you received your fuselage? Use that as a starting point to tie down the fuselage.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-07-2018, 08:48 PM
Bill Boyd's Avatar
page 6 of this thread http://www.vansairforce.com/communit...ght=unforeseen
should show how we did it in an enclosed trailer. Stuff fits fine at that stage of construction. Just lash it down well and insure it fully
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 11-07-2018, 08:53 PM
Timberwolf Timberwolf is offline
I paid to have a murphy moose moved from Chicago to Florida. I couldn't have come close to the price by the time I paid airfare, rented a truck, paid for gas, etc. Plus I didn't have any of the headache of trying to deal with the move. A VAF'er helped load it and a group of buddies helped unload it. Plus, he had the setup in his trailer and the knowledge to move such projects that really made everything go so smooth. I would recommend looking into it.
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P in progress
Aero Engineer, A&P
Old 11-08-2018, 09:06 AM
Paddy's Avatar
Paddy Paddy is offline
Default Moving
I moved a completed airframe from Long Beach, CA to Chicago. First, I had to move it to my hangar at Fullerton airport to store it for a few months and for that, I rented a U-Haul truck. The wings went in their stand alongside the fuse on it's dolly. Flaps and ailerons were attached to the wings and secured with duct tape to fix them in place. The tail feathers were secured on the floor under the fuse. Plenty of room in the truck for it all.
For the cross country move, I hired Partain to move it. They used a car transport trailer (with a car in it as it turned out) to move it. The wings were strapped to the trailer sidewalls and the fuse kept on the dolly. Very happy with their service and would happily use them again.
Flying as of 10/30/16 after 8 yrs building
Old 11-08-2018, 05:51 PM
DRMA DRMA is offline
I had Partain transport my empennage completed at Synergy Air in Oregon, along with my QB Wings and QB Fuse kits from Van's in a single shipment to Houston, TX. They did an excellent job, did the loading in Oregon and unloading in Texas, and helped me get it all moved into my shop. I highly recommend them as a specialist in aircraft moves.
I suspect the cost would be higher with Tony Partain than moving it yourself with a U-haul truck, but it would be much easier and probably safer using Tony.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
Old 11-09-2018, 07:10 AM
rleffler's Avatar
rleffler rleffler is offline
I used a rental truck and it worked well.
Landing gear werenít attached, so it made loaded the fuselage easier. None of the tail feathers were attached either. The wings were in the wing stand cart. Everything was lashed down. Nailing some 2x4 boards into the floor helped to keep the cart from moving.
Make sure you get a truck without wheel wells. It makes loading and packing much easier.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-09-2018, 08:59 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Landing gear weren’t attached, so it made loaded the fuselage easier. None of the tail feathers were attached either. The wings were in the wing stand cart. Everything was lashed down. Nailing some 2x4 boards into the floor helped to keep the cart from moving.
I managed to do it with a truck that had wheel wells. The trade-off is the height you have to lift the parts.
All of the major parts of a QB fit in this size truck, 26ft IIRC -
Buy lots of lashing straps, wood screws and 2x4s. No need to drill into the floor but you can make custom sized supports attached to the rolling carts to prevent fore/aft and sideways movement. Two or three good helpers loading and unloading made it go well.
I only had to go 80 miles, I'm not sure I could have taken that uncomfortable truck ride for 2 days...
ADDED
I now remember why I couldn't screw into the floor... it was a metal floor...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-09-2018, 10:57 AM
lr172 lr172 is offline
I bought a complete QB kit,. minus the finishing kit and moved it this way with no problem. Everything fit with a lot of room to spare. The big issue was that it would not fit in a 16' truck with the door closed and that forced me into a 24' truck, which is a lot heavier. The rental was a good bit higher, but the killer was fuel. I couldn't get better than 8 MPG and around here, diesel is more that gas.
N64LR
RV-10 in progress
Old 11-09-2018, 11:00 AM
I was the guy who helped load the Moose and spoke at length with the mover. If you do hire, I strongly recommend Timberwolf's guy. More affordable and very competent.
N64LR
RV-10 in progress
