Old 11-07-2018, 10:23 AM
Burtonport Burtonport is offline
Default Match Drilling Roll Bar
Hello. The plans (page 24iS-02, step 5) state to match drill the roll bar assembly while it is attached to the F-1231D Roll Bar Bases. I phoned Vanís support and they verified that procedure. Did you guys find that you had to sit inside the fuselage to match drill the holes on the inside curve? Thanks.
Regards,
Damien Graham
12-1072
Damien Graham
Watertown, NY
working on 12iS Fuselage
Zodiac 601 HDS, bought from builder 6-09
VAF dues paid until 7-20
Old 11-07-2018, 12:02 PM
It necessary to meet whatever body contortions are necessary to ensure drill is picking up center of hole and that drill bit is square to the surface.
Have funÖ
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 459
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
Old 11-07-2018, 12:29 PM
It seems like it would be easier to match drill the holes when the roll bar assembly is flat on a table, but I guess that it might not lead to a properly aligned roll bar, so into the fuselage I will go!! Thanks.
Regards,
Damien Graham
12-1072
Damien Graham
Watertown, NY
Old 11-07-2018, 12:43 PM
Regards,
Damien Graham
12-1072
All of the iS fuselage builds I have been involved with; this was done standing beside the fuselage from the outside. You are final drilling existing holes to proper size..... it takes very little force/effort exerted on the drill.
Scott McDaniels
Hubbard, Oregon
Old 11-07-2018, 01:21 PM
I just found that by turning the fuselage on its side and letting the roll bar assembly hang out from the table that I am able to access the holes to be match drilled without having to climb into the fuselage.
Damien Graham
Watertown, NY
Old 11-07-2018, 02:30 PM
rcarsey rcarsey is offline
I was able to do it easily with the fuselage on the ground (on a piece of carpet). There are a LOT of holes to final drill (plus the exterior-surface holes which then get countersunk!). For the holes which were on the curved surfaces of the rollbar, it was a little difficult to make sure you were drilling straight in... and I'll admit not 100% of mine were as straight as I would have liked... but were acceptable.
Take your time... and don't hurt your back while leaning over constantly..
