Old 11-06-2018, 10:34 AM
MED MED is offline
Default Wing Tip Lens
FYI - Do not use a Sharpie to mark the cut lines in the wing tip light lenses. Isopropyl alcohol wonít remove them! Fortunately, ethanol will, with time and flooding. Took me twenty minutes to get rid of the marks.
MED
140236
N435MD reserved
Old 11-06-2018, 11:08 AM
John Tierney John Tierney is offline
I used grease pencil/china markers for layout on my plexi-glass.
John Tierney
Salem, WI
RV-7A - Final Assembly
N777JT
Old 11-06-2018, 03:42 PM
MED MED is offline
Good idea. Now, if I could only find one . . . No luck at Staples, Walmart, Publix. Iíll try Home Depot next.
MED
140236
N435MD reserved
Old 11-07-2018, 07:32 AM
kbalch's Avatar
kbalch kbalch is offline
I just ordered these from Amazon:
https://www.amazon.com/Sharpie-2173P.../dp/B000BQS168
Ken
RV-8 N118KB (sold)
RV-14A #140494 (Fuselage in progress)
N114KB (reserved)
Old 11-07-2018, 07:48 AM
sblack sblack is offline
I use fineline flexible vinyl tape. It can be stretched to go around compound curves and it can be applied and removed and reapplied if you need to tweak it a bit.
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2018
Old 11-07-2018, 07:57 AM
Painter's tape spanning the cutting area, with sharpie marks on the tape??
Old 11-07-2018, 09:01 AM
lr172 lr172 is offline
It's been a couple of years, but I believe that I was able to remove sharpie marks with mineral spirits. MS are a preferred solvent for cleaning acrylic; I used it on the whole canopy to get rid of the adhesive from the covering.
N64LR
RV-10 in progress
Old 11-07-2018, 05:44 PM
MED MED is offline
Thanks for the suggestion, but I tried mineral spirits on the way to ethanol. It didn't work. My wife suggested hairspray, but she didn't have any for me to try.
I didn't have a problem with the first lens, but I guess I just got lucky and didn't have any marks in the middle of the lens that I needed to remove.
By-the-way, Home Depot has grease pencils. They call them China Markers. Not a very clean line, but they don't cause any damage and the marks are easy to remove. I may try the fine line tape if I ever have to do this again.
Thanks for the suggestions from everyone.
MED
140236
N435MD reserved
Old 11-07-2018, 06:05 PM
Suggestion - do NOT use Acetone to clean stray epoxy off of your wingtip lenses (or canopy, I expect).
Bad things happen.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-08-2018, 06:01 AM
MED MED is offline
Bad thing happen.
Ditto with MEK!
MED
140236
N435MD reserved
