Old 11-06-2018, 08:43 PM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
Originally Posted by Sam Buchanan View Post
Tom, I'm not suggesting anyone delay replacing hoses. However, the stainless braided hose with rubber lining that I've used in the RV-6 since 1999 have never shown any form of failure or lack of flexibility each time I have rebuilt them. This gives me confidence the hoses are reliable for my service intervals.
Just another data point.
My mechanic said the same thing. From what I remember, all the things that you can check for including the crunchy sound weren't happening with my hoses. I'm not making an argument one way or another.
So Tom, what do a set of hoses go for for my app? You can PM me if you like. Thanks.
Old 11-07-2018, 04:40 AM
Hoses are cheap and easy to replace. Set a time frame to replace and inspect for leaking annually. A metal tag attached to each hose gives replacement specs.
TURBO YES =VAF= Payed Jan2019
RV6-A 5,100+ hrs, R-44 1,600 hrs, Helicycle 320 hrs, gyro sold,35,000 miles flown in 2015
https://i.postimg.cc/tn3h4svg/IMG-3101.jpg
Old 11-07-2018, 07:09 AM
FinnFlyer FinnFlyer is offline
Default Still flexible not a good test
I had just had my annual condition inspection done by an A&P. He said the fuel hoses still felt good (steel braided rubber) -- flexible.
Turning on fuel pump for the next flight I smelled gas.
I took off the cowling, turned on fuel pump and saw gas spewing out through the steel braid!
Granted it's high pressure (40 PSI) and I run mogas.
Now I'm using non-steelbraided hoses and replace them every 3 years.
Finn
Old 11-07-2018, 08:39 AM
AndyRV7's Avatar
Finn
everyone's worst nightmare!
Old 11-07-2018, 08:50 AM
JonJay's Avatar
JonJay JonJay is offline
I went nine years 685 hours on my 303's. I know folks who have gone much longer, but youre taking your chances. Mine where still in great shape. I cut a couple open for inspection.
I package up the hoses and sent them to Tom to copy.
One caution. The Teflon hoses are a bit stiffer than the 303. I had to modify some routing as a result so it may not be an exact swap. My 303's where within tolerance for bend radius and the Teflon could make those turns but I didn't like how they "loaded" some of the fittings so I changed the routing a bit. Not a big deal and Tom's product with integral firesleeve makes for a cleaner install.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-07-2018, 10:04 AM
N941WR's Avatar
N941WR N941WR is offline
On a carbureted O-360, the following are the hoses I remember needing:
1. Gssolater to fuel pump
2.:Fuel pump to carb
3. Accessory case to oil cooler
4. Oil cooler to accessory case
5. Fuel pressure line
6. Oil pressure line
7. Manifold pressure line
Did I miss anything?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-08-2018, 07:29 AM
Sam, are using mogas?
Tom
Ridgeland, SC
Old 11-08-2018, 07:31 AM
Finn, my point EXACTLY!
Tom
Ridgeland, SC
Old 11-08-2018, 08:14 AM
Sam Buchanan's Avatar
Sam Buchanan Sam Buchanan is online now
been here awhile
Tom
Non-ethanol premium 90% of the time, the remainder is 100LL.
Once again, I'm only relating my experiences, not trying to encourage a particular hose replacement protocol and certainly not being argumentative.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 11-08-2018, 03:00 PM
Sam, we also are not trying to be argumentative. We are just relaying information based on our experience.
Tom
Ridgeland, SC
