Old 11-08-2018, 10:08 AM
664781 664781 is offline
Default Fuel Injection
Tried to install it on an 7A with fuel injection. Won't fit, will need several bends to get over the pump and filter box.
Kurt Lohmueller A&P
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 11-08-2018, 01:14 PM
PerfTech's Avatar
PerfTech PerfTech is offline
…. We have seen so far, three different height dimensions on this fuel pump
box. The bar clears the lower ones but we now have a few reports of some
having an interference issue. It would be very helpful to us if some of you
guys with fuel injected models could post the height dimension from the floor
to the top of your fuel pump cover. We will immediately build an "Easy Exit Bar"
to accommodate these models. Please do not order if you have this pump
cover on your aircraft until we have this potential problem solved. We are
very sorry if this is causing anyone concern or extra work. Thanks, Allan .
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 11-09-2018, 10:40 AM
n18pf's Avatar
n18pf n18pf is offline
Default Fuel injection measurements
Allan,
I measured my fuel pump/filter "doghouse". This is a per plans RV7A. The doghouse is 2 inches below the fuel selector which is 4 -5/8 inches up from the channel. It is the same width as the fuel selector - 5 inches. I've got some pictures with a ruler laying on it that I'll send to your "info" email address.
I hope this helps. Your product sounds intriguing if it would just fit in my plane!
Paul A. Fisher
RV-7A N18PF
Q-200 N17PF
APRS track
Old 11-09-2018, 11:14 AM
terrykohler terrykohler is offline
Default Anti-Splat Aero Easy Exit Bar
A+
Another winner from Allan and his West Coast "Skunkworks".
Fits perfectly. Easiest "add-on" I've ever put on 3TP. Works great. Just gotta figure out a durable finish that will blend into my finished interior.
Terry, CFI
RV9A N323TP
Old 11-09-2018, 11:31 AM
PerfTech's Avatar
Originally Posted by n18pf View Post
Allan,
...Thank you so much as this does help! It appears these dimensions are the
most common and the tallest as well. Thanks again. Allan..
Allan Nimmo
AntiSplatAero.com
RV-9A / Edge-540
(909) 824-1020
Old 11-09-2018, 01:41 PM
jpowell13 jpowell13 is offline
Default Exit Bar
Here's a picture of my Easy Exit Bar installation showing the fuel selector area. I like the fact that it gives me a secure place to stow my tool bag ahead of the main spar and between the pilot and pax's legs.
Having used it after a two hour flight yesterday, it made exiting the plane much easier, and didn't get in the way at all during my flight. I'm 66 and was beginning to dread lifting myself out of my 6A. No problem at all now, and cockpit entry is also easier.
John
Old 11-11-2018, 08:10 AM
rolivi's Avatar
rolivi rolivi is offline
Allan -
I guess I'm somewhat of a fan. I have your skid, stiffener, and gust lock. Haven't gotten around to sending the wheels in for the bearing mod, but it's on my list.
Question on this one. Can installing this bar eliminate stepping on the seats? That would be huge for me, with my nice fresh Classic Aero leather seats.
Thanks!
Rob
RV-6A (Purchased)
2019 Dues Paid, of course
Old 11-11-2018, 04:32 PM
NYTOM NYTOM is offline
Default Two piece model?
Allan I have a fairly big console with fuel shutoff, fuel gauges, parking brake control etc. Have you thought about a two piece model with a separate bar for each side.
I have plenty of existing bolts in the spar I could attach to on the onboard side in my 6A. May even purchase your existing bar and modify it myself to fit. I think you’ve hit a home run with this accessory.
Tom Norwood
Classic "Short Tail Six" A Model N822PM (Res)
99% done, 1% to go! Oh so close!
Old 11-12-2018, 05:29 AM
Tooch Tooch is offline
Default Step on seats
"Can installing this bar eliminate stepping on the seats? That would be huge for me, with my nice fresh Classic Aero leather seats."
I installed one a few weeks ago. You still have to step on the seats. I just have an old towel that i put down.
Old 11-12-2018, 08:55 AM
PerfTech's Avatar
….This does not eliminate the need to step on the seats. That would
really be a great product if I could come up with a solution! Thanks, Allan..
Allan Nimmo
AntiSplatAero.com
RV-9A / Edge-540
(909) 824-1020
