Old 11-05-2018, 08:49 AM
dmat dmat is offline
Default RV6 Tip-Up Panel CAD?
Does anyone have a cad file of the panel with an additional 2-3 inches added to the bottom? And possibly cutouts that can be bent around the bow instead of adding an angle bracket. (I have seen these done on other model panels and it would be great if I could do it on my 6)
RV6A: N6389-->N456RJ - Avionics Ugrade & Restoration underway--- SO CLOSE to finalization
Old 11-06-2018, 07:32 AM
Snowflake's Avatar
Vans has all of the panels on their website: http://vansaircraft.com/public/downloads.htm
I have a solidworks file of the -6 panel that I added one or two inches to, but I forget which. If you compare it to the plans you should be able to figure out which it is. PM me your email address and I can send it your way.
Rob Prior
Old 11-07-2018, 07:40 PM
Jesse's Avatar
Jesse Jesse is offline
The RV-6 wasnít prepunched, so they are all a little different. Vanís doesnít have a CAD file for them. There are a couple of ways to reproduce.
352-427-0285
jesse@saintaviation.com
Old 11-07-2018, 08:23 PM
Snowflake's Avatar
Van's does have a CAD file for them. They have a 2-D file. That's what I used to make my 3-D one. It matches measurements taken from the panel in my -6, so I have to expect that it's "close enough for practical purposes."
You can use the old one as a template to match drill the mounting holes so it lines up with your existing substructure.
Rob Prior
Old 11-08-2018, 05:56 AM
10builder's Avatar
10builder 10builder is offline
Default Up North
Alternately, you could probably contact Bill at Up North Aviation (upnorthaviation.com) and have him cut a new panel to your specifications.
Brian S.
Arrington, TN
SPA Panther N87XP (flying in phase 1)
RV-10 N104BS (Sold)
2019 VAF donation cheerfully submitted!
Old 11-08-2018, 08:22 AM
az_gila's Avatar
az_gila az_gila is online now
Exclamation CAD Accuracy
Be cautious following the top curve on any CAD panel for the -6 models. This is the drawing a lot of them were made to, and the accuracy varied from builder to builder.
You would be better getting a panel water-jet cut from a data base that is slightly over size on the top edge and undersized on the notches and then trimming using the old panel as a template.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
