Go Back   VAF Forums > Main > VAF Classifieds (posts in here deleted after 30 days)
Old 11-02-2018, 01:45 PM
purduecheer purduecheer is offline
Default FS: RV-7/9 Rudder and RV-7 Horizontal Stab (with SB 14-01-31 done!)
I am switching my RV-7 tail kit to an RV-8 which will require I build a new HS and Rudder. I just completed the RV-7 tail kit yesterday and did the lengthy service bulletin on the Horizontal Stab. Fiberglass tips for the HS not included as I will need them for the RV-8.
I am a military pilot and an A&P so rest assured that the build is good quality.
So, if you don't feel like doing the Service Bulletin on your HS (it is lengthy!!), you can buy mine, paint it, install it on your RV-7 and fly right away.
RV-7 Horizontal Stab (setup for electric trim) - $800
RV-7/9 Rudder - $400
Both - $1100
Pickup only (Converse, IN). This will give you a chance to check the work quality also.
https://photos.app.goo.gl/GJ76jiUYDEYMcBB27
https://photos.app.goo.gl/P7hCmonivJ5tTXo78
Pictures to follow. FYI, this is my first post so learning is in progress.
kc135flyer at hotmail dot com
Old 11-02-2018, 05:20 PM
mdevans9 mdevans9 is offline
Hi Brian,
I have thought about changing to an RV-8 rudder on my -7. Please help me out here. Why can't you just change the rudder, and keep the vertical and horizontal stabs as they are?
Merrill
Merrill D. Evans
RV-7 Flyng!
N87EM
Old 11-02-2018, 07:04 PM
I am changing planes going from an RV-7 to an RV-8. Horizontal stab is different and the rudder is different so I have to build new ones of those. That leaves me with an extra HS and Rudder is all.
Old 11-02-2018, 07:54 PM
BillL BillL is offline
Originally Posted by mdevans9 View Post
Hi Brian,
Merrill
You can do that. The "8" rudder is the same rudder originally shipped with the 7 kits. It just needs a new VS cap, nothing changes on the HS, and new stops, like the drawing. The 8 (early 7, late 6) has top and bottom glass unique to it.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Old 11-02-2018, 07:58 PM
Ah, okay Brian. Now I understand that you are changing from a -7 to a -8. Thanks, and all the best!
Merrill
p.s. Thanks Bill. We have corresponded about that. Do you still intend to test the -8 rudder?
Merrill D. Evans
RV-7 Flyng!
N87EM
Old 11-08-2018, 05:14 PM
Question Help me
Fellas, help me out. My wife wants the RV-7 parts gone before I order the -8 parts. The itch is strong so if you are on the fence, please...I really wanna get started on the -8 HS and Rudder. Am i asking too much?
