Old 10-29-2018, 10:49 AM
n38139's Avatar
n38139 n38139 is offline
Default RV-8 Bent Stick
Anybody start doing these again, I need one?
thx
Steve
Old 10-30-2018, 09:07 AM
N729LS's Avatar
N729LS N729LS is offline
You've already explored adjusting the rod-ends in the elevator system to move the stick aft? Because of the lever ratio, a small amount of rod adjustment can yield a goodly amount of stick movement.
Andy
Andy Elliott, CFI, RV-8, N303RV
Flight Reviews, Dynamic Prop Balancing
KFFZ, Mesa, AZ
Old 10-30-2018, 09:43 AM
mill2978's Avatar
mill2978 mill2978 is offline
thx
I've been able to adapt the RV-14 bent stick from Tosten into my 8. I've just started flying and don't have much to report yet.
The adaptation was cutting down the straight stick, making a sleeve to allow the smaller 14 stick to fit tightly in the 8 stick, then cutting the 14 stick to fit with the military style grip(also from Tosten) to clear the panel. I also had to remove an inch+ from the seat ramp for full travel. I think I may have been able to avoid some/all of the cut if I'd adjusted the rod ends differently.
It's on the list of things to refine in phase 1.
Aaron Miller
RV8 N127KT - First Flight October 16, 2018
Donation made for 2018
http://www.mykitlog.com/AaronMiller/
Old 10-30-2018, 11:08 AM
Steve and I talked about this a while back. Dies for the CNC bender, and a probable mandrel to do it right are EXPENSIVE. Probably not enough to justify the expense. BUT----we'll see.
Tom
Ridgeland, SC
Old 10-30-2018, 10:45 PM
VA Maule VA Maule is offline
Cerrobend & an Eastwood Tubeing bender #21115
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
