Old 10-28-2018, 05:19 PM
wirejock's Avatar
wirejock wirejock is offline
Default Mount
Maybe someone mentioned it but you'll need a mount for the tube. Dynon doesn't come with a mast. Some use Gretz others SafeAir or similar.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 10-29-2018, 06:47 AM
Tooch Tooch is offline
Default Van's pitot
I took the original Van's pitot off my plane when I replaced it with a heated one.
If you want it, make me an offer.
Old 10-29-2018, 08:29 AM
Default one for Safe Air.
We used the Van's tube tell we wanted a Garmin G3X with a heated Pitot tube. The Safe Air tube turned out to be the best and easiest to install in place of the factory stock one. It is a solid mount using the rivet holes on the rear of the main spar to hold the front edge of the mount.
Hope this helps, Yours, R.E.A. III # 80888
Old 10-29-2018, 09:54 AM
mfleming's Avatar
mfleming mfleming is offline
Dynon sells a very nice Mast. It will work with the Dynon or Garmin pitot tubes.
Personally, Iím not impressed with the Gretz mast.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated and so should you
