Old 10-27-2018, 11:47 AM
exercise exercise is offline
Default wing tank attach bolts/washer/nut
Hi Guys,
I can't find what hardware(bolt, washer(s) nut) to use to secure the fuselage bracket and tank attach angle in the leading edge wing root. Where in the plans(paper or disc) would it show it? Torque?
THX, John in MN
RV4 salvage project
IO-320 C/S
hope to fly it in 2018
0601054 att gmaill dot comm
Old 10-27-2018, 11:58 AM
rv8ch rv8ch is offline
Default RV8 tank attach bracket
Here's a clip from what I have on Drawing 43 to buy you a bit of time - I'd check with the factory to ensure that it's the same for the -4. You can get the preview plans from Van's on USB key for a few $.
Mickey Coggins
http://rv8.ch
Old 10-27-2018, 01:16 PM
FinnFlyer FinnFlyer is offline
DWG 39.
R6, R7 and R8.
Also page 8-10 of the manual.
I don't think I've seen a torque spec, but not much -- should be able to relatively easily tear our of the slot in case of wing being pulled back in a crash.
Before manufacturing F-463 see http://gikonfuse.blogspot.com/ Thursday, February 15, 2007, F-463 completed and earlier.
Interesting that on the RV-8, F-463 does not attach to lower longeron. Would make it a lot easier and lower bolt/screw will be hidden by straight wing/fuselage fairing.
Finn
Originally Posted by exercise View Post
Hi Guys,
Old 10-27-2018, 01:49 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
This previous post was specifically for the -4 -
http://www.vansairforce.com/communit...58&postcount=3
But the link may not be active - or may be it doesn't work because I'm presently in the UK...
Or this post for a -3 might also help - http://www.vansairforce.com/communit...59&postcount=4
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
