Old 10-25-2018, 02:58 PM
SgtZim SgtZim is offline
Default fuel line to servo IO-360
I just mounted the throttle and mixture cables and brackets and I'm scratching my head on how to best mount the fuel line from the pump to the servo. That mixture bracket is right where I was going to have brackets for the fuel line, and there is not a lot of room between the bellcrank and the sump for the line to drop down and turn to the servo.
I'd be concerned about the fuel line chafing on the sump even though the sump edge is nice and round and there is the firesleeve. At the back end, there is very little room between mixture bracket, engine, and engine mount.
Any ideas?
Thanks!
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 10-25-2018, 04:40 PM
pilot28906 pilot28906 is offline
I have a 7 with the same engine and the fuel line misses the mixture bracket but it either hits the intake tubes or the engine mount. I can't seem to adjust the Adel clamps to where it misses both. I sent photos to Van's and they said to keep it off the engine mount and RTV it to the intake tube. I will probably play with it some more using additional clamps. I can send some photos of what I have so far if you would like; not too good posting here.
John Johnson
Murphy, NC
RV7
Old 10-26-2018, 11:44 AM
Bruce, different sumps, servos, and yes even exhaust contribute to the hose routing.
Tom
Ridgeland, SC
Old 10-27-2018, 06:07 AM
I think it will work out ok - Now that I have the mixture completely hooked up, I see that the bellcrank doesn't need to swing all the way back and come close to the fuel line. I will need to probably fasten a hose clamp onto the mixture bracket to keep the hose from chafing on the bracket or the engine mount. Kinda wish Van's had not cut three large lightening holes in the bracket. I'll post photos when I get this done.
RV-8 slow build
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
