Old 10-24-2018, 02:09 PM
JwWright57 JwWright57 is offline
Default Testing Lights
Hi all - i'm getting close to finishing my wings and would like to test the lights, any idea how I can do that?
Ideally it would be great to test from the Blue connectors on the wing ribs to the lights so all the connectors/wiring is hit.
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
Waiting for fuse kit, should be here in a few weeks!!
Dues paid 2019
Old 10-24-2018, 05:33 PM
mike newall's Avatar
Yep - you know all those pesky rivet mandrels......
Well, if you fabricate a wander lead with one as a probe for pos and one for earth, and use your Odyssey battery, you can easily test all the various light permutations apart from wig/wag.
They are very bright !
Donated in 2018
Old 10-24-2018, 06:52 PM
Bob Y Bob Y is offline
I used a 9-V transistor battery and it worked just fine.
Old 10-25-2018, 02:56 AM
dbhill916 dbhill916 is offline
I bought a set of the blue connectors and the appropriate pins from Vans, then several meters of wire from a local electronics store. I fabricated an umbilical cord that was long enough to run from either side of the fuselage to the wing storage rack and was able to test the landing light, Nav/Strobe lights and the stall warning switch very easily. It came in handy again a year later when the L strobe stopped working.
I just ran pin1 to pin1, pin 2 to pin2, etc. Weave 3 wires at a time to keep them together. (You'll need a string to be the 3rd 'wire' for wires 7 & 8) and then weave those 3 bundles together for the final cable. That will prevent the need for tie wraps that tend to hang up on things when you move things in the shop.
David B. Hill
N76012
RV-12 #0760
http://n76012.blogspot.com
Dues paid through 6-2019
Old 10-25-2018, 07:40 AM
John-G John-G is offline
+1 for the 9 volt battery
I used a couple of test leads with small alligator clips on the ends attached to a 9 volt battery and tested each light one at a time for a few moments to check continuity ... the LED lights get plenty bright on 9 volts.
Happy building,
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 10-25-2018, 12:01 PM
Thanks for all the suggestions
Rv-12 started!
Tail 99% done
Wings 99% done
Dues paid 2019
