Old 10-23-2018, 06:49 PM
jcarne's Avatar
jcarne jcarne is online now
Default Control colum pushrod question F-665
Hello everyone, I was wondering, did your length come out anywhere close to the suggested length by Van's? I'm assuming the two control sticks need to be parallel. If I do this my connecting rod is significantly shorter than the Van's 18-7/8" on the drawing (my rod ends are almost bottomed out into the hex tube). Thanks!
question by Jereme Carne, on Flickr
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 10-23-2018, 07:00 PM
JonJay's Avatar
JonJay JonJay is offline
Can you get the jam nuts on? Does the end of the hex rod and/or jam nuts stay clear of the stick weldment at full deflection?
If those answers are YES, you should be good to go.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 10-24-2018, 05:15 PM
jcarne's Avatar
Thank you good sir, I'll go ahead and check that. Just thought it was weird how far off from the recommended dimension it should be.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Finish kit arrived
Old 10-24-2018, 05:25 PM
JonJay's Avatar
Well, that is weird. This was not all that uncommon in the earlier kits, but you might double check with Vans. I was just at the weldment suppliers shop a few days ago having them weld up a hole I put in my boat. (Long stupid human story, me being that stupid human.)
The control weldments are made in a jig. They couldnít vary. There was a whole stack of them getting finished up.
So, my guess is the plans are just a bit askew.
Bucker Jungmann
RV1 - Proud Pilot.
Old 10-24-2018, 08:23 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Hi Jon, youíre right about the jig/fixture and itís same fixture today that the first control column was built on for the first production RV-6, probably even the prototype, fixture has never been changed.
Russ McCutcheon
www.mccutcheonmetalfabricationaviation.com
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 10-24-2018, 08:59 PM
jcarne's Avatar
Well after looking at it a little closer and snugging things up I have found that the stop nuts still have threads past them and nothing seems to be interfering. At first I was thinking the different in measurements was on the edge of 1/2-3/4", turns out it is only 1/4". I think I can live with that unless someone thinks that I shouldn't, I see no reason why not.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Finish kit arrived
Old 10-27-2018, 12:45 AM
If you look very carefully at the bottom of WD-611 & 612 you will see the heat, hammer and anvil formed welded stampings that attach the aileron linkage to the sticks are not fit to the right and left stick in an exact mirror image (I know because I built them) this probably accounts for your ¼” more than anything else.
I think your fine, I might even go out on a limb and say all control linkage dimensions should be considered approximant and are adjustable to correct for any variances in the linkage system.
Russ McCutcheon
Old 10-27-2018, 10:08 AM
jcarne's Avatar
Thanks Russ, your insight into this is very appreciated! I went ahead and installed everything, seems to all fit great.
20181025_181520 by Jereme Carne, on Flickr
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Finish kit arrived
Old 10-27-2018, 10:28 AM
Looks great Jereme, you keep that up and you're going to end up with an airplane!
Russ McCutcheon
