Old 10-21-2018, 08:21 PM
Burtonport Burtonport is offline
Default Longerons
Hello. I am building the 12iS and I received the fuselage kit last month. I was pleasantly surprised to see that the longerons had been pre-bent. I just finished section 22 and I sat down tonight with the plans for 23, which is the side skins. The first page deals with bending the longerons. Have you guys that are ahead of me found that the pre-bent longerons are good to go or does more bending need to be done? I thought that I remembered a recent post about this but I could not find it with a search. Thanks.
Regards,
Damien Graham
Damien Graham
Watertown, NY
VAF dues paid until 7-20
Old 10-21-2018, 08:52 PM
Does it matter what others found if yours fit?
Old 10-21-2018, 09:02 PM
rolick22's Avatar
rolick22 rolick22 is offline
They are pre bent but the first 12" needs to be opened and twisted per the instructions on page 23iS/U-02 for the best fit. Use a bench press with half inch socket for the radius. If you don't your longerons will deform and curl and you will be sad like I was and have to order a new one.
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
N112DR
VAF donation made for 2020
Old 10-22-2018, 07:47 AM
Thanks very much Dave. That is just the kind of info that I was looking for.
Damien Graham
Watertown, NY
