Old 10-21-2018, 06:34 AM
rolick22's Avatar
rolick22 rolick22 is offline
Default Garmin AP Roll Pushrod too Short for iS installation
The pushrod that I made (5 1/4 inch) IAW 44B-02 dated 4/02/14 does not appear to be the correct length for the iS installation. I have tried to install the AP servo with the rod end this way but it is way to short. The stick is approximately in the neutral position. Guessing the geometry is a little different then the original ULS installation with the manual flap handle. I know there is no avionics plans yet available for the iS but maybe someone knows if the length of the pushrod for iS installation is different or the same. I have double check the rod length of all the other push rods and they check out good.
______________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
Empennage finished
Wings finished to iS standard
iS Finishing Kit Finished
iS Fuselage Finished (mostly)
iS Engine Kit in work
iS Avionics Kit in work
1st GEN FUSELAGE SOLD
Serial#12-0864
N112DR
VAF donation made for 2019
Old 10-22-2018, 06:40 PM
rolick22's Avatar
Default Update GSA 28 Push Rod on the iS
Update on anyone doing Garmin
David Rohrlick
PPSEL A&P
Empennage finished
Serial#12-0864
N112DR
Old 10-23-2018, 11:46 AM
subpar_bucker subpar_bucker is offline
Here I was all impressed that you had ordered your 12iS compatible avionics kit! I keep waiting for the announcement of when those will be available!
Old 10-23-2018, 08:30 PM
rolick22's Avatar
Sorry, I wish I at least had the builder instructions.
David Rohrlick
PPSEL A&P
Empennage finished
Serial#12-0864
N112DR
Old 12-26-2018, 11:31 AM
rolick22's Avatar
I will defer to Vans, as I don't have a engineering degree.
David Rohrlick
PPSEL A&P
Empennage finished
Serial#12-0864
N112DR
