Old 10-18-2018, 10:49 AM
todehnal todehnal is offline
Default ADSB 472
I finally have my Dynon dual receiver ADSB 472 on the way. Has anyone installed the upgrade from the ADSB 470? I was wondering if the mounting was the same, and just a matter of replacing the unit, or if mounting needed to be modified.
Thanks. I'm sure that I will figure that out when I open up the avionics compartment, but a heads up sure would be nice......Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 10-18-2018, 10:54 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Randy King did this as I'm sure others too but this one is fresh in my mind.
http://www.vansairforce.com/communit...39&postcount=5
Physical box differences.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 10-18-2018, 10:55 AM
Raymo's Avatar
Raymo Raymo is online now
Haven't done the swap but the mounting is not the same (472 is much smaller) and the connectors are now on opposite sides vs the same side on the 470. You'll only be able to re-use one existing mounting hole.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 10-18-2018, 11:46 AM
Mitch757 Mitch757 is offline
I ordered "Skyview ADS-B Bracket", p/n F-00045C from Vans. Cost is $5.00 and makes the conversion much easier. I did it all by removing the Skyview.
Mitch Garner
Old 10-18-2018, 12:26 PM
Mitch Garner
Thanks Mitch. Between the picture from Carlos, and your part number, this should be a no brainer. I'm sure that I won't need any documentation. It looks like it is just a matter of installing the new bracket, which I imagine goes on top of the SL40 in place of the ADSB-470 and mounting the ADSB-472 to it....Tom
Old 10-19-2018, 08:12 AM
John-G John-G is offline
Tom-
As mentioned by others, to make the install easier you will want the new mounting bracket. The new bracket uses the same mounting locations above the radio that were used to mount the 470 unit. Below is a photo of a completed instillation ... my finger is pointing to the new bracket. Note how much smaller the 472 unit really is .... actually not a whole lot bigger than the DB connector.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 10-22-2018, 05:21 AM
Thanks John. Parts should be here tomorrow and you pic makes the installation process easy to understand............Tom
