Old 10-18-2018, 12:51 AM
mattsrv7 mattsrv7 is offline
Default RV-7 Roll Rate vs Tip Style?
I've tried to search but haven't had any luck on this question.
Has anyone flown the same -7 with the -415 wing tips and the -715 style tips doing aerobatics?
I'm curious if there is any noticable difference in roll rate or aileron feel between the styles. There's a little more area on both -715 versions around the aileron vs. the -415 in the plan view.
I really want to maximize the roll rate and feel on my -7 to try and keep it as close to my -4 as possible.
RV-4 Bought Flying
RV-7 QB Fuselage in Progress
Old 10-18-2018, 07:55 AM
Mel's Avatar
Mel Mel is offline
I did this wing-tip swap on my -6 and didn't notice any change in roll rate.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 10-18-2018, 07:06 PM
Thanks, that helps.
RV-4 Bought Flying
Old 10-18-2018, 10:39 PM
flytoboat's Avatar
flytoboat flytoboat is offline
Did you notice any differences?
Don
VAF #1100, EAA864
-6A bought flying
Old 10-18-2018, 11:18 PM
rocketbob's Avatar
rocketbob rocketbob is offline
The RV-4 I've had in my possession since July has flat tips and rolls very quickly.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 10-19-2018, 06:46 AM
judoka5051 judoka5051 is offline
Default Shorten Them!
I shortened the late style wingtips on My RV8A by 9 inches a side and got a noticeably faster than normal rate. I did have to do a bit of fiberglass work at the intersection, but it wasn't too bad. I had several folks tell me the climb would suffer, but that didn't happen. That plane climbs 1700fpm with 2 on board and half fuel... with 160hp.
Incidentally, my main goal was to keep the plane as light as possible.
Just did the same thing on the new build with older style wingtips. Hopefully with the same results.
Lance Logan
Stuart, FL
Plane at X58
Scratchbuilt Biplane
Preceptor N3 - Sold
Zenith Zodiac 601HD - Sold (good riddance)
Kitfox IV - Sold my share, but loved that plane
RV8A Sold! Loved the plane, but not the nosewheel!
RVX (RV6/4) Sold
RV8 Project purchased (Can't help myself)
Old 10-19-2018, 07:26 AM
Mel's Avatar
Mel Mel is offline
I was hoping to see a reduction in stall speed with the increase in span. Actually the span increase is only at the trailing edge and doesn't increase the area very much.
I perceived no difference in any performance parameters at all.
Aerodynamic theory says that the original Hoerner style tips should be more efficient. My theory is that the slight increase in span/area of the new tips cancels out the loss in efficiency.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 10-19-2018, 10:55 AM
Raymo's Avatar
Raymo Raymo is offline
A friend with an RV-8 installed some carbon fiber flush tips (with a small bump out in the middle). This was done for speed / drag reduction but would, in theory, help with roll rate.
Tried to find them on the interweb but didn't come up. If interested, I can find out where he bought them. One negative is that they do not allow for wingtip lights or antenna.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 10-19-2018, 12:53 PM
N941WR's Avatar
N941WR N941WR is online now
You could bolt on regular position lights on them and remove the tail light and strobe, thus saving weight.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-20-2018, 12:21 PM
If you can find the carbon tips I'm interested to see how they look.
RV-4 Bought Flying
