Old 10-17-2018, 02:08 PM
Originally Posted by lr172 View Post
Not sure what is happening here, but I believe that the shop head should be made by the material making a nice 180* turn, with the end of the rivet, after the 180, touching the backing plate. In your picture of the "Good" rivet," your material just makes a little tulip, with no contact. I would be concerned with these loosening over time.
Not an expert here, but I believe this type of rivet requires the full turn with the end of the rivet material pressed against the backing material. Take a look at a picture of a manufactured brake pad. It achieves it's objective very differently than a solid rivet. It is a lot more like a formed grommet.
I agree
The rivets labeled good, are not good.
Either the tool that is being used, or the technique being used is suspect.
Scott McDaniels
Hubbard, Oregon
Old 10-22-2018, 05:53 PM
Update...
I emailed Matco and showed them pics of my rivets, and like Scott says, none are any good. Turns out the riveting tool I was using is not up to scratch. Matco suggested a screw-type rivet press and so I bought a Rapco Brake Rivet Tool RA825 from Aircraft Spruce and it does a beautiful job. Rivets are now rolled over tight against the backing plates. Easy-peasy like my triplet granddaughters say. Continuous learning process I guess...
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 446
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
