Old 10-17-2018, 05:27 AM
Default Matco Brake Relining Kit Problem...
It won’t be too much longer and I’ll need to install the first set of brake pads that I relined myself using Matco Brake Relining Kit and a Brake Shoe Lining Riveting Tool. The two backing plates are different thickness and require either a short or long Matco brake rivet.
My concern is that with the thicker plate and longer rivet I can’t get a good “shop head”. The thinner plate and shorter rivet make a good “shop head”. It seems like the thicker plate should have a counterbore for the “shop head” like on the thinner plate.
Anybody else got this problem?
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 10-17-2018, 06:09 AM
snopercod's Avatar
Default Flip the thick plate over
I think I see the problem. The thick plate seems to be flipped upside down. The pads should be on the other face. In left frame of the first photo, you can see the round wear mark where the puck pushes on the plate. Those should be on the back side right? Nice photos, BTW.
(2018 dues paid)
Old 10-17-2018, 08:00 AM
No, the thick plate is the stationary plate that bolts solid to the caliper. Piston only pushes on the thin plate that slides on pins. The thick plate doesn't have counterbore on either side, so I'm totally at a loss here.
I emailed Matco and await a response which I will share soonest...
Hinckley, Ohio
EAA #499867
Old 10-17-2018, 08:25 AM
Mel's Avatar
Mel Mel is offline
If I understand you correctly, the think plate doesn't back up against anything. If that is the case, why are the protruding rivets a problem?
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Tony_T's Avatar
Tony_T Tony_T is offline
Default Swiftline service
Save the hassle. Buy the Swiftline kit. It is basically another set of shoes and linings.
After your SwiftLine purchase, any time you send your brake shoes in with spent linings, they will be relined for 20% off the cost of the reline kit. There is no labor charge removing the old linings and installing the new ones ! Call for a Return Merchandise Authorization (RMA) number when sending in shoes with spent linings to minimize the turn around time.
Send the spent brakes in as soon as you change them and you then always have a spare set of brakes ready to go on the shelf. Once you have the Swiftline service this is cheaper than installing linings yourself and it's done right.
Of course, you may actually enjoy riveting on brake linings?
Tony
RV-12 #202 -- Flying
Old 10-17-2018, 09:02 AM
lr172 lr172 is offline
Not sure what is happening here, but I believe that the shop head should be made by the material making a nice 180* turn, with the end of the rivet, after the 180, touching the backing plate. In your picture of the "Good" rivet," your material just makes a little tulip, with no contact. I would be concerned with these loosening over time.
Not an expert here, but I believe this type of rivet requires the full turn with the end of the rivet material pressed against the backing material. Take a look at a picture of a manufactured brake pad. It achieves it's objective very differently than a solid rivet. It is a lot more like a formed grommet.
N64LR
RV-10 in progress
Old 10-17-2018, 12:26 PM
tomkk's Avatar
tomkk tomkk is offline
+1 I do this as well, works great.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 10-17-2018, 12:48 PM
ChuckC ChuckC is offline
I too use Swiftline. Quick and easy. Recommend you do what Tony suggests.
Chuck Carlson
120445
Old 10-17-2018, 01:31 PM
BigJohn BigJohn is offline
Another vote for Swiftline!
“Master Pilot” Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 10-17-2018, 02:14 PM
snopercod's Avatar
This is what my MATCO brake looks like, You can see where the puck pushes on the thick aluminum piece. Apparently, yours are different.
(2018 dues paid)
