Old 10-13-2018, 08:38 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Default Ready for winter flying
Getting ready for cold weather flying - oil shutter installed to keep engine temps up at -10
Installed seat heaters for me - keep my temps up!
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2019 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 10-14-2018, 02:51 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
We had a temperature record yesterday (Netherlands / latitude 52N ) for the 14th of October; around 25C/77F and you're starting the winter flying thread?😉
Any information about your seat heating (brand/Amps)?
Regards, Joeri
PH-BZT
MyKitlog
Picasa pictures
Old 10-14-2018, 07:04 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Engine preheater?
I feel your pain, it got down to near 60F last night here! Do you have an engine preheater? I put on an oil sump heater last year. Its nice to have your engine at 90F before starting.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 250+
2018 Dues Paid
Old 10-14-2018, 07:32 AM
Dvalcik's Avatar
Regards, Joeri
3.5 amps per seat
Tech Era Carbon Fiber Seat Heater Kit
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2019 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
Old 10-14-2018, 07:42 AM
Tandem46's Avatar
Tandem46 Tandem46 is offline
Currently 22 degrees F here in Denver at 6:40am. Several inches of snow on the ground too!
RV-7 Flying since 2004
1,000 hrs+
Old 10-14-2018, 12:04 PM
benburb benburb is offline
Where did you get the damper for the oil cooler?
Old 10-14-2018, 02:59 PM
Dvalcik's Avatar
Van’s, but antisplat now has them. I had to put a fabricate frame. Look up one of my posts from a few years ago
http://www.vansairforce.com/communit...hlight=Shutter
https://antisplataero.com/
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2019 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
Old 10-17-2018, 08:24 PM
mikesmithstormlake mikesmithstormlake is offline
Default Bottom cowl removal
Does this shutter make removing the lower cowl a pain? I assume you must disconnect and remove the shutter. What about the cable? do you have to thread it through the cowl each time?
Old 10-17-2018, 09:06 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
29 degrees Monday morning here when I went flying. I installed an oil cooler shutter but not the Bowden cable. Basically wire it full open for summer and full closed for winter. Last winter I plugged in my Reiff oil Sump Heater on November 1st. and left it on until March 1st. (fly every week or two). I also use a cowl blanket in between uses. It maintains an oil / case temp in the mid 90s. Even down to -40 F. Keeps the whole front end warm. On cold days I also throw a milk house heater in the cockpit while I do my preflight. Darn thing starts up smoother in January than it does in June!
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
www.mykitlog.com/dbro172/
1968 Mooney M20C - Sold
1956 C-182 - Sold
