Old 10-13-2018, 05:57 PM
Top Cat Top Cat is offline
Default Help needed to fix SkyView screen
I just received a refurbished SkyView Touch from Dynon.
Everything is okay...EXCEPT...there is a line/bar which cuts horizontally across the top tool bar, cutting out half of displayed info. Its not black it has colors in the band across the screen. If it was my MacBook Air I could put the cursor on the edge of the area and drag it bigger. Its almost like a second tool bar going across the top.
It’s Saturday so before I contact Tech Support Monday for a fix or return to them...again...I wondered if anyone knows if I can fix this by editing the top of screen? Or doing something in the settings. I went through every option on the screen today in the airplane but couldn't find anything.
I’ve read Installation and User Manual no help. I took a screen shot but it doesn't help, although it shows a normal top tool bar whereas on the unit this is partially obscured.
Unit has the latest firmware 15.3.4
Thanks!
Old 10-13-2018, 06:05 PM
Try posting this in VAF>Avionics / Interiors / Fiberglass>Glass Cockpit
Fellows there are very helpful...
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 10-13-2018, 07:03 PM
Thanks, Iíve added it there too.
Old 10-13-2018, 07:38 PM
rswalden's Avatar
rswalden rswalden is offline
Default Make Sure It isn't the Runway You Are Looking At...
Be sure the line you are seeing isn't the synthetic vision display of your airport's runway, Can you post a screenshot for us? Is the line present when you display other screen pages such as EMS or MAP? It's very easy to misinterpret the black line you are seeing on the PFD display when it is simply the runway.
Bob Walden (Waldo), CFII-ASMEL
KFFC "Falcon RV Squadron" Peachtree City, GA
RV-7A Tip-Up, IO-390, 450+ Hours
RV-12 (Sold)... RV-12 Transition Training
EAA/AOPA/Vans Air Force 2019 Supporter
Old 10-13-2018, 07:43 PM
Bob
I did take a screen shot but it doesn’t show anything. Screen shot shows everything normal on top tool bar.
In the plane the top of top tool bar is covered whenever screen is on.
I know what you mean about the synthetic vision runway but it isn’t that.
Tomorrow I’ll try and take a photo of it.
Old 10-13-2018, 08:28 PM
tomkk's Avatar
tomkk tomkk is online now
I don't think there's anything editable up there in the way you're describing. My guess it's going to have to go back to Dynon.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 10-13-2018, 09:22 PM
Thanks Tom,
I was afraid of that😔
Old 10-15-2018, 01:23 PM
Dynon sending me another replacement unit for the replacement unit as it’s a fault in screen that can’t be fixed.
Thanks for the help.
