  #41
Old 10-24-2018, 10:22 AM
Adam Adam is offline
Dan,
Did you make up your own cables?
Adam Silverstein
Technical Counselor Chapter 643
Flying RV-8 10/30/07
Pittstown, New Jersey
Old 10-24-2018, 01:59 PM
scsmith scsmith is offline
Originally Posted by Snowflake View Post
It seems it shouldn't be that hard for a competent builder to make a prototype and prove the change would be an improvement.
Personally I haven't had a problem with my Rocket Link...
It would not be difficult to cut one out of normalized 4130 sheet. But it would require taking it somewhere for heat treat to make the latching notch durable.
I suppose I could cut one out of 17-4PH.
Also the link arms need to be longer. For a proof-of-concept, I could use a stacking nut as an extension, but I would not want to trust that very long.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 550
also LS-6-15/18 sailplane
VAF donation Jan 2019
Old 10-24-2018, 02:02 PM
Originally Posted by RV7Guy View Post
If you guys are referring to the Silver Bullet Link, JD Air was born after getting taken for my money after ordering one. Found out later several others had problems too.
The JD Air link looks much like the Silver Bullet but thats it. It was a clean sheet design with much improved innards. We have sold hundreds of these with very few problems. Keep in mind tail wheel components take a beating back there. If you try to lift the tail with the steering link, it will break.
Many if not most of the failures (about 6 over 10 years) are caused by improper maintenance of the tailwheel assemblies. They need to be cleaned, the locking pin and arm checked and everything regreased on a regular basis. I used to do it every oil change while the oil was draining. About 20 minutes start to finish.
Definitely don't be afraid of a steering link type system. It is positive and will give you years of service with proper maintenance. We have them in stock and ready to ship.
Darwin, I would be delighted to work with you on a modified steering arm geometry, and an accompanying longer link.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 550
Old 10-24-2018, 11:07 PM
DougCronkhite DougCronkhite is offline
I'll probably grab one of your links when I get home in March.
RV-8 N188LC
Dues Paid 11/18
Old 10-25-2018, 07:39 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by Adam View Post
Dan,
Yes. Oval swage sleeves are not difficult.
Maybe more than you want to know...
https://www.danhorton.net/VAF/Chains...Squeeze_r2.pdf
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-25-2018, 09:56 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Steve,
Terry Jantzi was the original designer of the steering links, now made by Wayne Hadath, and sold by Blake through www.flyboyaccessories.
Blake would be happy to also work with you on any improvements to the geometry. That way we all win. We're all in this together, eh?
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
Old 10-25-2018, 10:26 AM
Toobuilder's Avatar
Originally Posted by JonJay View Post
I am curious. Is the Rocket or other type of asymmetric push/pull single rod system ever been used on any other tailwheel aircraft or is this just an RV developement?
I have never seen any other tailwheel aircraft with a single rod...
Steve Wittman used a single arm unit decades before there were any RV's. Many of the early Tailwinds and racers were so equipped.
These were solid rods and the tailwheels had no swivel function, but I think your point is the asymmetric actuation, which these share.
Michael Robinson
______________
RV-8 - Flying
Old 10-25-2018, 10:28 AM
vfrazier's Avatar
The Sonex series uses a solid, single rod. There are others too.
Vince Frazier
www.f1aircraft.com
Old 10-25-2018, 10:59 AM
JonJay's Avatar
JonJay JonJay is offline
Cool. Thanks.
As always, the knowledge base here is amazing.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 10-25-2018, 02:14 PM
Snowflake's Avatar
The solid rod versions with no swivel are not really comparable to this situation. I think the issue people see with the Rocket/Flyboy/Jantzi links is that the asymmetry affects how the "release" actuates depending on which way the wheel is turned. I know when my pin wears, one side wears faster than the other. If I let it go too far, i'll end up with positive steering turning one way, and full swivel turning the other way.
Regular maintenance (disassembly, regreasing, checking pin for roundness) of the assembly seems to prevent this.
Rob Prior
