Old 10-22-2018, 01:09 AM
Bevan Bevan is offline
I have my VOR/ILS antenna on the top of the vertical fin. I obtained piece of square tube (approx 3/4-1” square not sure), mounted it to the top rib under the tip. Then mounted the antenna to the tube. This way the antenna is raised up a bit so you don’t have to cut the flange off the the top rib. It is all well concealed except for the rods sticking out which shouldn’t be much drag as they are swept back at about 45 degrees. Works perfect.
Bevan
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 10-22-2018, 08:28 AM
longranger's Avatar
longranger longranger is offline
Originally Posted by whd721 View Post
...I now have a Comat 157p and plan to mount it on the rudder. I was pleased to find the current model has a hockey puck that is only about 1/4" thick. It should be nearly invisible way up there.
Thanks again.
Hopefully you intended to say you’re going to mount it on the vertical stabilizer. You don’t want an antenna on a moveable control surface.
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on site
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 10-26-2018, 08:43 AM
whd721 whd721 is offline
The vertical stab would be the correct answer.
Typing in this little box seems to lower my IQ by a bunch.
whd721
RV9A
Sherwood, Oregon
As Bill Stout (designer of the Ford Trimotor) used to say, “Simplicate and add Lightness”
