Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #101
Old 09-16-2018, 07:14 AM
RV8iator's Avatar
RV8iator RV8iator is offline
Default Careful here.
Originally Posted by Tooch View Post
Before you load and activate the approach, press the vectors button and select the fix
Unless you are being vectored to the final. This is the reason for the vectors choice. When you touch vectors, it opens the window to display the IAFís where you can then select your choice. If you leave VECTORS there, it removes everything but thr FAF.
Jerry "Widget" Morris
RV 8, N8JL, 2700+ hours
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019
I just wish I could afford to live the way I do
Old 09-28-2018, 01:24 PM
PixelWorker PixelWorker is offline
The link to the firmware in the first post isn't working for me. Has it changed?
Michael Jensen
RV7A - Aero Country T31
Old 09-28-2018, 09:29 PM
Spirko Spirko is offline
The link on the first post brings you to all the Garmin updates. The bottom one is the GTN update and two above that is the support document. Both still work for me.
Old 11-08-2018, 08:56 PM
rwthompson67's Avatar
rwthompson67 rwthompson67 is offline
Trying to find the answer and I'm either too dense when reading the manual or otherwise mentally challenged...How do you update to 6.50? The manual talks about how a "GTN Software Loader Card can be created using a GTN Downloadable Software SD Card P/N 010-01000-00 in conjunction with a GTN software application downloaded from the dealer resource center on garmin's website".
So is this "Downloadable Software SD Card P/N 010-01000-00" something I need to buy from Garmin? Or can i just use a blank SD card? Or do I use one of the SUPP Data SD cards that came with my GTM-650?
Rick
Old 11-08-2018, 10:04 PM
sibriggs sibriggs is offline
Default Use a regular SD card
Software update page for G3X and GTN6XX
https://www8.garmin.com/support/coll...=155&pID=63892
Use this link on the bottom of the Garmin web page.
Service Bulletin 1859 - GTN 6XX/7XX Software Loader Image 006-B1367-3A, Ver. 6.50, as of Aug 29, 2018, Download
Steve Briggs. RV9, G3x, G5, VPX, GTN625, PMags, A&P, IA, ATP-CFII
Old 11-09-2018, 08:37 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
The GTN software update service bulletin has this note to explain that you do not have to buy a Garmin SD card to perform this update.
"The GTN Downloadable Software Data Card is a blank SD Card. Other commercially available 2-32 Gb standard-size SD cards formatted for FAT32 may be used. ".
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 11-19-2018, 10:34 AM
DickF's Avatar
DickF DickF is offline
Default GTN Ver 6.51
I have not yet installed GTN ver 6.50. Can I install ver 6.51 without first installing 6.50?
Dick Flunker
RV-6A, 1900+ hours
North Texas
Old 11-19-2018, 10:44 AM
g3xpert's Avatar
DickF,
Yes. You can go ahead and load GTN V6.51 from whatever software version you are currently using. Depending on the version of your current software, you may need to update databases. That information is all contained in the Service Bulletin: https://www8.garmin.com/support/down...s.jsp?id=12529
Levi
Garmin G3X Support
g3xpert@garmin.com
Old 12-20-2018, 09:53 PM
backcountry backcountry is offline
I have upgraded to the G3X Touch ver 6.21 & GTN ver 6.51.
However, I donít know what the improvements over the 6.20 & 6.50 verisions.
Question is there a write up available for this?
Old 12-20-2018, 10:19 PM
tgmillso tgmillso is offline
Not sure if you'll find a specific page detailing the comparisons between the two, however I generally find everything I need regarding GTN and G3X software updates on this page:
There is a document there that includes the release notes of GTN 6.51.
Tom.
