Old 10-16-2018, 11:45 AM
You are right Tom about the maintenance manual specifying flushing the fuel pressure hose at annual or at 100 hours. It would be interesting to know the reason for doing that. My philosophy is, if it is not broken, do not fix it.
Joe Gores
RV-12 Flying
Old 10-16-2018, 12:51 PM
Just spit-balling here... maybe because that hose is dead-headed and residual fuel doesn't get used and goes stale so-to-speak?
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 459
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
Old 10-16-2018, 01:21 PM
Azjulian Azjulian is offline
The scary thing in this case is that the debris wasn’t in the hose it was in the coupling from the hose fitting to the pump, so flushing the hose didn’t clear it
Old 10-16-2018, 06:19 PM
dick seiders dick seiders is offline
Interesting feedback,thanks. My plan is to pick up a mechanical fp gauge tomorrow and pull the floscan following psi test to determine what its problem might be.
Dick Seiders
Old 10-23-2018, 07:02 PM
Test using 0 to 15 fuel psi gauge clearly showed good fuel psi. Facet alone was 3.2 lbs. Rpm of 2000 was 5.88, 3000 4.8, 4000 4.0 4800 3.3 on static ground runs.
VDO was cleaned with brake cleanerand on subsequent tests ran just a little less than the 0to 15# instrument
at each stage.
Conclusion is that Joe Gores was right in his statement about fuel psi. But I may switch to a Kavlico for the greater reliability
Floscan problem turned out to be a loose ground wire.
Dick Seiders
