Old 11-06-2018, 09:42 AM
backcountry backcountry is offline
After 7 months the noise again returned. Sounds like squelch noise. Again I removed and reinstalled the comm connector on the 50001 box and once again the was gone but didnít last very long.
Has anyone seen this problem?
Vans eliminated the box on the new RV-12ís.
I feel as the aircraft ages problems will increase considering all those connections on the 50001 box.
Old 11-06-2018, 10:56 AM
Originally Posted by backcountry View Post
After 7 months the noise again returned. Sounds like squelch noise. Again I removed and reinstalled the comm connector on the 50001 box and once again the was gone but didn’t last very long.
Vans eliminated the box on the new RV-12’s.
Make sure it is not a problem related to the grounding of the box itself.
It is supposed to have a good ground to the airframe (I think internal tooth lock washers are used on the mounting screws to help with this).
When you R & R the harness cable you might be moving the box enough to influence the ground connection.
Also be sure that all pins are fully engage in the harness connector.
Scott McDaniels
Hubbard, Oregon
Old 11-06-2018, 12:12 PM
jartlip jartlip is offline
I had the same issue in my -4. It turned out to be the power cord for the Garmin 495. If I unplugged it, the sound stopped. I never did find a fix for it. I just ran the 495 on battery power and took it out of the airplane to recharge it every 10 hours or so.
RV-4
Old 11-06-2018, 12:27 PM
Also, try removing and re-seating the GTR200... fixed a crazy intermittent problem we were chasing on/off for months.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 459
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
Old 11-28-2018, 08:55 PM
Iíve tried everything I can think and the ideas made here.
Latest update
Noise cable suppressors added to 3 cables coming from the 5000 box.
Comm
Options
Autopilot
This seems to get rid of the noise. I donít know what the real problem is but I suspect it in the 5000 box.
Thanks for the ideas
