  #51
Old 10-20-2018, 12:40 PM
h&jeuropa h&jeuropa is offline
Mike,
Will the board manufacturer sell just one board? Or do you have a suggestion for those of us who just want to build one unit? I sure don't need 4 boards!
Jim Butcher
Old 10-20-2018, 05:33 PM
joedallas's Avatar
joedallas joedallas is offline
Default 2 Each
Jim
If you buy 4 boards, I will buy 2 of them from you.
If interested call or Email
Joe Dallas
727-857-9812
joe@rvbuildernet.com
Originally Posted by h&jeuropa View Post
Mike,
Jim Butcher
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 10-20-2018, 05:43 PM
joedallas's Avatar
Default A very professional job
Mike
I would like to know the changes you made to the circuit and why
I have wanted to do this and you saved me a lot of research
Thanks for sharing this design
Great job
Joe Dallas
Originally Posted by MMiller View Post
A few weeks ago I scratch built a new voltage regulator to replace the Ducati.
My design goals were;
  • Low cost ďexperimentalĒ replacement
  • Repairable
  • All components are off the shelf (no custom extrusions, CNC, or molded parts)
  • A regulator with known ratings, all components have data sheets.
  • Built with common builders tools
  • Increased heat sink area
  • Eliminate Faston connections for the power leads
  • Maintain the Ducati mounting bolt hole spacing
  • Optional cooling fan
This is what I came up with;
Overview
Side by side
The parts cost about $60, not including the PCB.
Iíve only got a few hours on it, so I wouldnít consider it a proven design. If you have an interest in building an experimental replacement regulator, all the details can be found in this pdf file;
https://drive.google.com/open?id=1d6...fIhzrB4gktR3Ok
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 10-20-2018, 09:17 PM
bpattonsoa bpattonsoa is offline
Perhaps you could answer a question.
I wondered about the light circuit. I was looking for it on the circuit diagram
See my post 44 in this thread. My regulator was so badly soldered that the light circuit came shorted out to the next pad. (The L and C pads) When I powered it up the regulator it got very hot with that fried component odor.. What could have burned out? If it just killed the light function, I don’t care, not used. If it could have killed the regulator then I will build one of yours a little earlier than I planned.
Bruce Patton
Rans S-20 Raven 796S Now flying (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S tail, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum, interior complete. 1624 lbs, FLYING after a 21.5 month build.
Old 10-21-2018, 08:38 AM
Mark33's Avatar
Mark33 Mark33 is offline
Default Rans S-20 build
Hey Bruce,....a little bit of a thread drift, but I see youíre building an S-20 Raven. Howís that build going? Do you like the overall quality of the Rans product and the building experience? After Iím finished with my current RV-7 project Iím planning on building a Rans S-7. I got interested in this thread because Iíll more than likely be installing the 912 in my S-7 project. I know that the Rotax charging system is a bit anemic and I also really donít care for any of the Ducati ignition system. So, my plan is to ditch the entire Rotax charging and ignition system along with ditching the carburetors and replacing everything with a single, belt driven, external alternator along with an electronic ignition and electronic fuel injection (EFII) system like whatís now available for our Lycoming based engines. Iíll basically be building my own version of the 915. If youíd like to P.M. or email any details of your S-20 build to me, thatíll be fine. Once again, Iím sorry for the thread drift, but Iím just trying to educate myself about these Rotaxís every chance I get.
Old 10-21-2018, 08:54 AM
Look in your private messages, my phone. I was Crew Chief for the first Reno racer to run the SDS EFI system with very positive results. Can provide good info on Rans also.
Bruce
Bruce Patton
Old 10-21-2018, 10:07 AM
Dave12 Dave12 is offline
A bit more drift. Which wing are you using Mike?
Wag Aero Sport Trainer sold and wrecked
N588DF RV12 #336 Sold, alive and well in New York
N73DF RV12 #244 Sold, alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
