Old 12-28-2015, 09:03 PM
I put my VOR/GS cat whiskers in the same spot, butI haven't been able to get a good signal yet. I'm not sure what's going on, but I'll figure it out at annual.
To me "light IFR" means IFR in VMC in congested airspace or marginal VFR.
Old 12-29-2015, 12:47 AM
Bill_H's Avatar
Bill_H Bill_H is offline
You need some better advice! Do NOT NOT NOT go EAB instead of ELSA for the reason you mention in the original post!!!
See this thread.
http://www.vansairforce.com/communit...d.php?t=122599
Bill H, RV12, N412BR "Sweetie", Skyview-equipped, KASL Marshall TX
Old 12-29-2015, 05:07 AM
Handclutch Handclutch is offline
I am also interested in getting my aircraft into IFR (light) for the reasons outlined above. Agree that it isn't a great IFR platform - rather twitchy - and I would never consider flying it in difficult IFR conditions, but it is soooo much easier flying in the IFR system compared with VFR. I had forgotten how much work is involved in flying VFR!
Is anybody running a heated pitot with the standard Rotax alternator? Spruce has 7 amp heated pitots (most are usually 10 amp) - seems like the Rotax might just handle it if everything else is kept to a minimum.
I had read about the alternator that bolts on the back of the engine - looked like it would easy to fit and a good solution, although pricey. However, I have just contacted Sportair who advise they are no longer available because they had become too expensive. I'm waiting on further advice to find out whether manufacturing has ceased altogether, or whether it's a case of Sportair no longer stocking them because of the cost.
Any other thoughts on fitting an external alternator? I understand there is one available that fits to the back of the gearbox but I suspect the airbox might get in the way on the 12, unless it is smaller than I imagine.
Old 12-29-2015, 07:39 AM
Dave12 Dave12 is offline
Governor, do you want to take this one?
Wag Aero Sport Trainer
N588DF RV12 #336 Sold
N73DF RV12 #244 Flying
Rans S21 Outbound (Coming soon)
Old 12-29-2015, 08:45 AM
Mel's Avatar
Mel Mel is online now
Please be aware that it is not necessary to go EAB for the reason of going IFR. An ELSA may be flown in IMC if properly equipped and flow by a qualified pilot.
The VFR restriction is for Sport Pilots and not necessarily related to the aircraft.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-29-2015, 12:34 PM
bhassel's Avatar
bhassel bhassel is offline
Originally Posted by TomVal View Post
Here is a photo of my VOR antenna location:
Regards,
Tom
ah, come on, give me a photo of the rest of the plane!
Bob
Bob Hassel
NM
Subscription Paid for 2018
Home is where the hanger is...
Old 12-29-2015, 06:48 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Regards,
Tom
Would love to see rest of paint job.....looks cool.back side
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 12-29-2015, 07:44 PM
TomVal's Avatar
TomVal TomVal is offline
Bob & Ric, thanks for the interest. Sorry about the thread hijack.
Here was the inspiration:
Regards,
Tom
Craig AFB, Class 71-06
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 12-30-2015, 10:45 AM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Default ? about Ext Alt
Here is a post from 2012 for my external Alt. There is large amount of customization from hoses, to fiberglass work switching the air intake, and wireing. I have a VPX that manages the 40 amp alt and uses the Rotax as a backup.
http://www.vansairforce.com/communit...&highlight=alt
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2019 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 11-02-2018, 12:38 PM
randylervold's Avatar
randylervold randylervold is offline
moderator
Default VOR antenna
Originally Posted by aerofurb View Post
We have an SL30 with the VOR aerial mounted on the fin top rib. The fin tip is held on with #6 countersunk screws into anchor (plate) nuts.
The aerial base is mounted with screws into anchor nuts onto a simple top hat bracket rivetted to the top rib. Slots in the fin tip allow the aerial to pass out through the tip.
The aerial lead passes down through the fin leading edge rib lightening holes and forward through the fuselage. There is a BNC connector under the leading edge fin attachment bracket access panel to aid fin removal.
Works fine. Note, we are in the UK rules so our mod rules are different.
Van's appears to have located the cat whisker antenna in the same location on their RV-12iST. Does anyone have a recommendation on a specific antenna and/or pictures of how they mounted it?
I know some builders locate these antennas at the base of the rudder but in my experience they are a pain in the butt down there as you're tying the plane down and so on. I need to make some quick decisions here as I start into my VS.
Randy Lervold
RV-12iS, empennage/tailcone, wings & fuse on order
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
