Old 12-28-2015, 09:11 AM
backcountry backcountry is offline
Default IFR RV-12
My aircraft is mostly complete except for the avionics & power plant.
The aircraft will be completed to the E-LSA specs but certified E-AB. The reason for doing this is I later plan to make some small instrumentation changes for IFR. I'm not doing this to fly hard IFR but I will fly IFR in weather that I could fly VFR. For X-country I like IFR but that would be a problem for certified E-LSA. I've flown an RV-12 and in light IFR I would feel as comfortable in it as any other aircraft.
Has anyone done this?
Has anyone installed a VOR antenna?
Old 12-28-2015, 09:53 AM
BigJohn BigJohn is offline
This topic has been discussed/debated several times before. Search the forum for previous threads. As to the VOR antenna, yes I have seen it done.
“Master Pilot” Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 12-28-2015, 10:24 AM
bhassel's Avatar
bhassel bhassel is offline
If you're doing the EAB just for updating to IFR later (as in after the pink slip), you can still do that as an ELSA, as long as you do the updates after the pink slip.
That's what I plan to do.
Bob
Bob Hassel
NM
Subscription Paid for 2018
Home is where the hanger is...
Old 12-28-2015, 12:46 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Default Question
How do you file for Light IFR?
Sorry, I couldn't help it.
Tony
RV-12 #202 -- Flying
Old 12-28-2015, 01:24 PM
Dave12 Dave12 is offline
I installed a Garmin SL30 in my previous 12 and mounted the VOR antenna on the bottom fiberglass tailcone and routed the wire through a snap bushing and forward through the fuselage. In that 12 I had the Dynon D180 system and used it's internal VOR/GS indicator and it worked very well. I did fly quite a few hours with foggles using that set up. My personal opinion is that the 12 is not a good IFR platform. It's too light, thus a bit too twitchy for ILS approaches. It would also need a heated pitot mast. The 12 is a great airplane, but is not designed or intended as an IFR platform. Just my opinion fellows.
Wag Aero Sport Trainer sold and wrecked
N588DF RV12 #336 Sold, alive and well in New York
N73DF RV12 #244 Sold, alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 12-28-2015, 02:15 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
I do not believe your statement regarding e-lsa is true. Once certified as an e-lsa (certificate in hand); you could change out to a certified GPS/nav....up date transponder... You could legally fly ifr....like you said, say a marginal approach at destination (would be nice to shoot a GPS approach).
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 12-28-2015, 02:31 PM
Phantom30's Avatar
Tony,
I've been vfr in the San Jose area (Reed Hillview airport) where I would have given anything to call approach control and request a GPS approach.....it was legally vfr, but not to my liking.
Light ifr.....is very subjective, would not on purpose punch into weather, but as noted above...to let down through a cloud base. I guess I don't see what all the fuss is about.
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
Old 12-28-2015, 02:39 PM
aerofurb aerofurb is offline
We have an SL30 with the VOR aerial mounted on the fin top rib. The fin tip is held on with #6 countersunk screws into anchor (plate) nuts.
The aerial base is mounted with screws into anchor nuts onto a simple top hat bracket rivetted to the top rib. Slots in the fin tip allow the aerial to pass out through the tip.
The aerial lead passes down through the fin leading edge rib lightening holes and forward through the fuselage. There is a BNC connector under the leading edge fin attachment bracket access panel to aid fin removal.
Works fine. Note, we are in the UK rules so our mod rules are different.
Jerry Parr
England
RV-12, G-TWLV
Loving Rotax....
Old 12-28-2015, 02:43 PM
TomVal's Avatar
TomVal TomVal is offline
Here is a photo of my VOR antenna location:
Regards,
Tom
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 12-28-2015, 04:22 PM
DonFromTX's Avatar
I put mine in the same location, on top of the vertical fin.
Retired US Army Officer
