Old 10-31-2014, 12:13 PM
MacPara's Avatar
MacPara MacPara is offline
Without looking at mine I think that I did not have an AN365 in that place. If I remember correctly (and that is a BIG caveat), mine had metal locknuts called out which are much smaller than the AN365 or plastic insert locknuts in general.
RV-12: #120374, ELSA, N128TL flying since Nov 28, 2013 (Phase 1 completed 1/26/14)
SkyView, Light Package, ADSB
http://torstensrv-12.blogspot.com/
APRS Track
Old 10-31-2014, 01:35 PM
tomkk's Avatar
tomkk tomkk is offline
Originally Posted by dbhill916 View Post
gents, thanks for the advice. I finally ended up taking the sticks out and attaching the pushrods, then unthreading the pushrod from the bearing and re-installed everything in place.
I now have a new problem: with the stick full back and full roll (either direction) the pushrod rubs against the AN365 lock nut on the forward control blocks. Has any one else had this problem? I'm waiting for some half-height nuts (AN364, IIRC) to see if that permits free travel, but I'd like to find out why they are rubbing in the first place.
Thanks again for any insights!
-dbh
Having a bit of trouble with the picture but, if it's the bolt I'm thinking of, I had that problem and had to flip it around and put the nut on the other side as Bob suggested earlier.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK in progress
Old 10-31-2014, 01:57 PM
That would put the nut on the bottom of the belly of the airplane.
I am pretty sure MacPara has it correct.
The fastener in question is supposed to be a screw (head on the outside of the belly skin), with the small MS all steel nut (much smaller than the AN365 nut shown in the photo)
Scott McDaniels
Hubbard, Oregon
Old 10-31-2014, 02:13 PM
tomkk's Avatar
Ahhh, yeah, you're right - that's the top of the systems block under there ...
Tom
Port Orange, Fl
Old 10-31-2014, 04:28 PM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
Originally Posted by paul mosher View Post
Are the flight control devices and the stops in place? The throw will be reduced with flight controls installed.
The throw is not reduced with the flapperons in place. The throw is limited by the flapperon mixer.
At page 31-13 you can see the hardware to be used. It calls for an AN365-832. From what I remember I installed very small all metal locknuts. The hardware in the picture looks too big.
PH-BZT
MyKitlog
Picasa pictures
Old 10-31-2014, 06:31 PM
Rrhsch Rrhsch is offline
I have the same issue. I think the flap handle is to far forward. I am continuing with the build because I don't think this is a problem. I think it will not be an issue once the flaperon control is completed.
Old 10-31-2014, 06:45 PM
paul mosher
Posts: n/a
Oh, sorry! The point I was making is that the throws are going to be different when the DEVICES are connected. I think the mixer is considered a device.
Old 10-31-2014, 10:02 PM
I know of instances where builders have installed the the flap handle with the UHMW bearing blocks positioned / oriented incorrectly and it does cause the flap handle geometry to be incorrect and induce some strange issues.
Scott McDaniels
Hubbard, Oregon
Old 11-01-2014, 09:33 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default Flap pushrod
Have seen this when the flap handle to mixer pushrod are too long. If you haven't drilled the flap torque tubes, I'd try screwing the pushrod in further.
Good luck
Alan
RV-9A N984AW
Old 11-02-2014, 07:25 AM
Bill_H's Avatar
Bill_H Bill_H is offline
Don't be changing lengths of ANYTHING on the RV-12. Recheck the plans. Follow the plans. Make the control rods the exact lengths that the plans say. Use the exact parts and hardware the plans say. Mantra: If something does not fit, STOP! The likelihood is that the problem does NOT lie with the kit!
And check the RV12 forum thoroughly using search. Check the blogs for that kit section like Schmetterling Aviation and Marty Santic's and Tony Tessitore's picture set.
Bill H, RV12, N412BR "Sweetie", Skyview-equipped, KASL Marshall TX
