Old 10-10-2014, 03:51 PM
Stockmanreef Stockmanreef is offline
Default Question: Riveting Bottom Skins
Before I embark on riveting the bottom skins on, I figured I would ask how to do it. I think that I can figure out the outboard skin, but how the heck do you rivet on the inboard ribs that are close together. Also the plans say to rivet the inboard skin along the rear spar, back half of the ribs, and the J-channel. Do you leave some of the rear spar and ribs so the skin can be pulled back?
Are there any good videos out there on riveting on the bottom skins?
thanks
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 10-10-2014, 04:40 PM
bruceh's Avatar
bruceh bruceh is offline
Assuming the -14 wing is similar to the -9, you first put the bottom skin on with about 3 or 4 rows of clecos starting from the rear spar and then moving forward.
You can pull the skin back and get under there to buck. I used some duct tape to help keep it folded back. As you progress row by row forward from the rear spar it gets tighter and tighter to access from the forward edge. You should be able to do the remaining inboard panel rivets under the wing walk by reaching in through the holes in the wing ribs from either side, or use the access panel hole.
If you don't yet have a small tungsten bucking bar, now would be the time to get one.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 10-11-2014, 05:59 AM
Ron B. Ron B. is offline
I followed Van's riveting instructions to the letter and it worked out for me. If I remember correctly the rivets next to the flap hinge (brackets) were the toughest ones for me.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 10-11-2014, 08:59 AM
wirejock's Avatar
wirejock wirejock is offline
Default Lanyard
Get some Gorilla tape and string. Make a lanyard so you don't drop the bar.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 10-11-2014, 09:12 AM
MikeyDale's Avatar
MikeyDale MikeyDale is offline
I just installed my bottom outboard skins this week without any helpers. (Quick Build wings)The first one was a real battle but the second one was much easier as I learned how to position myself. My arms took a beating and I noticed after the first one they were bruised up close to my shoulders.
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
First Flight https://www.youtube.com/watch?v=QqgxhWH3pqA
Build Blog http://mikesrv7.blogspot.com/
Dues Paid
Old 10-11-2014, 10:14 AM
wirejock's Avatar
Default Arms
It helps a little to wear long sleeves or cut the toes out of some old tube socks and slide them over your arms.
Larry Larson
Estes Park, CO
Disclaimer
Old 10-11-2014, 11:15 AM
My preferred method...
Stuff some old towels in the bay you are working in and lay them out on the skin at the bottom (laying on inner surface of top skin). That way, if you do drop the bar the skin is protected (it also gives you something a little nicer for your arm to rest against).
Scott McDaniels
Hubbard, Oregon
Old 10-11-2014, 04:19 PM
Maybe I am interpreting the plans wrong:
"Cleco the W-0004L Bottom Invboard Wing Skin to the bottom flange of the rear spar, to the aft half of the wing ribs, and to the wing box J stiffener short."
So the skin is clecoed up to the J-stiffener before you start riveting. It would be much easier to cleco the rear spar, then part of the ribs (not up the j-stiffener).
Not saying easier is the correct way to do it.
Ken Stockman
Midland, MI
Old 10-11-2014, 05:59 PM
You're interpreting it correctly.
The goal is to have the skin clecoed down as much as possible to assure alignment, but still allow access inside.
With it clecoed as described, the skin will pull open enough for the bucking arm can reach in from front towards the back for riveting the J stiffener, and everything aft of that (the reason long sleeves were recommended already). Then the skin can be fully clecoed down, and everything else is accessible from each end, and through the access cover holes.
Do as much as you can on the outboard skin first, then cleco on the inboard skin and repeat.
Scott McDaniels
Hubbard, Oregon
Old 01-21-2018, 04:37 AM
mturnerb mturnerb is offline
Resurrecting another old thread. I have QB wings. Questions about riveting the outboard bottom wing skins:
1. On page 20-04, the very last instruction is to rivet the overlap joint. I'm confused by this - shouldn't I rivet the aft-most parts of this join sooner, since the skin needs to be rolled back to access for riveting the aft section of skin (as is done on the rest of the skin.
2. How important is the chamfering of skin edges as described on page 16-02? The builders of my QB wing didn't bother to do this on the inboard skin as far as I can tell, and I am not too concerned about the cosmetics. I did ease the forward edges of bottom skins just a bit.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
