Old 11-03-2018, 04:58 PM
wjb's Avatar
wjb wjb is offline
Default Asymmetric top cowl trimming?
Hi Guys,
I'm using DanH's cowl trimming technique http://www.vansairforce.com/communit...60&postcount=2) and have set up equal gaps on the left and right inlets per Dan's instructions. However, I find when I go to mark the cowl, one side needs zero trimming, while the other indicates 10/32" worth. Pretty asymmetric! Has anyone else seen this?
I'm working on a newer pink cowl.
Bill Bencze
N430WB RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 11-03-2018, 05:55 PM
N941WR's Avatar
N941WR N941WR is offline
To compensate for P factor (torque) the engine is not mounted straight to the fuselage. Measure it, you will see what I'm talking about.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-17-2018, 06:47 PM
wjb's Avatar
wjb wjb is offline
So, not trusting that I was using DanH's method correctly (http://www.vansairforce.com/communit...60&postcount=2), I decided to mount the prop, level the spinner plate and laser it, bisecting the spinner plate (convenient alignment holes provided!). Sure enough, the left inlet is quite a bit larger than the right.
Left side: 10/32"
Right side; zero trim
Black lines were my first try on the floor; the laser pretty much confirms it.
However the overlap on the left side is pretty small .. 1/16" ish. Looks like I'll need to extend cowl edge a bit.
Bill Bencze
