Old 10-31-2018, 11:37 PM
pilotyoung pilotyoung is offline
Default Voltage Regulator
I know this topic has been discussed a lot. I bought a Silent Hektik regulator and am getting ready to install it. Earlier this year, I saw a post from a fellow that did a really nice job installing a Silent Hektik. He routed the blast tube from the left side of the engine, taping into the big air duct that supplies the radiator. He put a hole in the top in front of the radiator and then routed the blast tube to the sheet metal cover on the top of the regulator. It was very well done and he included several pictures of the installation. He said he positioned the hole for the blast tube so that he still had room to install a Bender Baffle, if he decides to do so it the future.
My problem is I have searched for, and can't find that post and his pictures. Can someone help me find that post and pictures?
Thanks so much.
John
John D. Young, RV-12 Owner
Serial Number 120022, N6812Y
Bought it as a flying airplane in Feb. 2018
Just passed 100 hours flight time in RV-12, and 10,000 hours mostly in corporate jets. I am a CFI; CFII; MEI; and a advancd Ground Instructor, CFIG; and hoping to be able to help new RV-12 owners by doing some transition training for new builders and owners in RV-12's.
Old 11-01-2018, 07:24 AM
mdoyle mdoyle is offline
I believe this is what you might be talking about. I asked Van's support about this since it used to be a part of the lighting kit. (DWG 40-14) I just purchased the lighting kit to add it to my RV-12 and noticed it was not included. This is their reply as to why it is no longer part of the lighting kit.
"The F-00002 was found to be ineffective and potentially cause higher temperatures, no longer recommended. We do have a different voltage regulator option if you would like to install it during your build but is in no way mandatory. New kits sipping today will have the new regulator." cost for the regulator and installation kit is $495
http://www.vansaircraft.com/pdf/revi...2/RV-12_46.pdf
pages 46-19-21 show the installation of the SH regulator on the current RV-12
This might be the post you were looking for?
http://torstensrv-12.blogspot.com/20...regulator.html
Mike Doyle
RV-12
RV-9A, Under Construction
Xenia, OH 45385
Old 11-01-2018, 09:43 AM
That was the post I was looking for. Thank you for finding it for me.
