Old 10-15-2018, 12:42 PM
aviti aviti is offline
Default Tail cone question
I've got the empennage done and getting ready to start the tail cone. Does anyone know if I can fit the tail cone through a 36" doorway if the vertical and horizontal stabs aren't mounted yet? I'd like to stay in my basement with the build as much as possible.
Tony Vitiello
Ballwin, MO
RV-12 ELSA
Tail kit complete
ULS Fuse kit in progress
Old 10-15-2018, 01:17 PM
rcarsey rcarsey is offline
I think it is slightly more than 36" wide.. but I will measure for you when I get to the hangar later (6pm edt).
Old 10-15-2018, 01:33 PM
tomkk's Avatar
tomkk tomkk is offline
I was able to easily get mine through a 36" doorway but it was a straight shot on both sides of the doorway - I didn't have to make any turns.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK in progress
Old 10-15-2018, 02:01 PM
rv9builder rv9builder is offline
I measured mine and got 39 1/2 inches wide at the top of the F-1280 skins where the built-in J-stiffeners are located. Height is about 33 inches, so if you turned it sideways, it could probably fit through a 36-inch doorway.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2019
Old 10-15-2018, 03:41 PM
Thanks for the info guys! I have a straight shot out my basement workshop door so it sounds like I'll be good. I was already thinking that turning it sideways would be the way to go. I really appreciate you guys checking.
Tony Vitiello
Ballwin, MO
RV-12 ELSA
Tail kit complete
Old 10-15-2018, 04:10 PM
Bob Y Bob Y is offline
If the door only opens 90 degrees, you’ll likely need to remove it from the hinges, like I had to do.
